Found a one owner 1950 D2 5U with 3940 original hours
Thank you received: 999
2 years 8 months ago #236104
by Rome K/G
Bravo! It might be easier if you shorten the pull by half, just a suggestion.
Markds3
Thank you received: 405
2 years 8 months ago #236105
by D4Jim
Nice sounding pony and main!! Thanks for posting.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
Markds3
Thank you received: 657
2 years 8 months ago #236111
Very nice Mark. Everything about that tractor is in good shape. Is that a 3J or Twenty-Two or something over the back in front of the LandRover?
Markds3
Thank you received: 185
Thank you received: 77
2 years 2 months ago - 2 years 2 months ago #240338
by Markds3
Can anyone verify if this is the original style of edge filter for the starting engine fuel bowl off this tractor? I was watching one of Toby's episodes on the starting engine rebuild and from his description I reckon it might be. Found it amongst the 'stuff' in the toolbox.
Last edit: 2 years 2 months ago by
Markds3.
Thank you received: 276
2 years 2 months ago #240339
by rax200
Hi Makds3,
Yes it is the filter that is fitted in the fuel bowl the part number is 9B4517 (Element)
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Markds3
2 years 3 weeks ago #241776
by Markds3
As you might have picked up I've got this old girl in the shop for some much needed maintenance:
One of the issues I've had is a constant seep of coolant from both the main engine block drain pet cock and also the air bleed one on the top of the starting engine. I tried lapping them with fine grinding paste and had no success. I research the part numbers and find I can order these from CAT:
However, even though it would work, and probably much better than the original, I don't feel that happy with the look:
Are the old original brass taper seat style still available, and where is the best place to source them?
Thank you received: 786
2 years 3 weeks ago - 2 years 3 weeks ago #241787
you can still get stuff like that online i cant remember the website though i think they also sold oil cups and i was looking for oil cups when i spotted em.
but first i would try flowing some silver solder over the tap core and lap em again. it just might work check with some engineers blue aka bearing blue or mark up dye to check the contact patch where the dye isnt disturbed or doesnt transfer is the low spot. clean and flux em with bakers soldering fluid or ezi-weld 801 liquid flux(801 is so strong you can solder monel and stainless stuff normal flux wont touch)
those new ones are probably brass and just chrome plated a few hits with a file to take the chrome off they wont look so ugly or spin em in the lathe and machine them slightly round carefull not to go to deep or youll cut the ball seat.
Time to create page: 0.434 seconds
