- Thank you received: 772
Thanks Juiceman, and I appreciate everyone's kind feedback. I took a picture of the drawbar and although I'm certainly not an expert and I know its not pristine it certainly isn't as bad a some I've seen!That is really nice to have found the goodies in the toolbox. Usually I only end up with a bucket of broken bolts, cotter pins and scrap basically. My own collection of CAT tools have slowly grown by means of purchasing tractors and scavenging thru each one for buried treasure. I did find a mostly consumed bottle of whiskey once, I returned that to the prior owner's family, as their father loved to pop the cork while greasing his tractor at the end of each day!
I am hoping you tell all of us that the drawbar holes are not egg shaped. I see that CAT pin, wishing the last person only used it, instead of anything that fit in the hole.
You surely have a tractor to be proud of. JM
Thanks so much for your help Eddie, you were exactly right, the ring holding the glass prises off and I was then able to hook the black gauge face out and clean everything out. All it needed was some lubrication on the tiny pivots and a good clean and it's back working perfectly. I tested it with my Mityvac and the needle maxes out at around 15psi. Just need to fit it back on the Tractor.Hi Mark,
from memory the black glass retaining ring pries off by delicately and evenly working around the ring edges with the likes of a narrow wood chisel.
For the needle I normally use two small screw drivers--one each side--to gently pry the needle off its spindle--there are puller tools for this if you so desire.
calibrationawareness.com/5-techniques-pr...ge-adjustment-repair
For conventional gauges this has a bit of less technical stuff.
hendersonkj.com/misc/oil-pressure-gauge-repair/index.html
These found by Googling "oil pressure gauge repairs" for a few minutes.
support@acmoc.org
- Chris R
- Jason N
