Found a one owner 1950 D2 5U with 3940 original hours
1 year 10 months ago #244593 by trainzkid88
yes a word of warning about those 3.5tonne ratings many dont realise that is only with nothing else in the vehicle except you and a tank of fuel as fuel, the spare tyre, factory toolkit, towbar etc are all counted as payload. the realistic tow rating is only about 2.8 tonne. and forget that 10 percent ball load bullshit its just that bull shit.
you should be able to still lift the draw bar when hitched to the vehicle and the load centred just forward of centre so its put a load on the hitch at all times. we had a 4wd that was rated for 2.5 tonne on a braked tandem trailer the max ball load was 50kg and thats all it needed and was perfectly safe. that vehicle itself weighed nearly 3 tonne.
just be careful and dont believe the marketing hype check the spec sheets carefully for your self, many have been caught out even big companies
1 year 10 months ago - 1 year 10 months ago #244632 by Markds3
Tonight I took some more pics in better light. Pony started first pull, main diesel lit right away, steering clutches work perfectly and oh so smoothly, no movement in the 'other' steering lever when steering (which there was before with the loose bevel gear shaft bearings), and absolutely no coolant leaks from either the radiator, water pump or the new block drain and pony air bleed! Very very satisfying I must say.
Last edit: 1 year 10 months ago by Markds3.
The following user(s) said Thank You: bcwayne, neil, kracked1, gauntjoh, rax200, seiscat, ekstenf
1 year 10 months ago #244768 by Birdie01
Holly crap Mark, that freight is ridiculous. I just jump on SIS yep the parts is in Clayton but my dealer here in QLD only wants to charge $22.40 aus for the spring and $49.00aus for air freight. so that should be around $77.00NZ for you over there.
The following user(s) said Thank You: Markds3
1 year 10 months ago #244769 by Markds3
Yup it is ridiculous. Fortunately I found a good secondhand spring which didn't cost me a thing!
1 year 10 months ago #244771 by trainzkid88
now i suggest you get some penertrol and turps in a spray gun and give the whole thing a coat to seal that paint and preserve it. it will also make it shiny.
1 year 10 months ago #244784 by neil
If you need anything less than suitcase size form the US, I'm visiting NZ again in March. Bearings and such would not be a problem
1 year 10 months ago #244786 by Markds3
Thanks Neil! I do need to get 16 new bellows seals for the track rollers from General Gear in Idaho, so I might just be in touch!
1 year 10 months ago #244801 by neil
Righto, let me know
1 year 10 months ago #244819 by trainzkid88
another option is to use a company that leases you a US postal address and then tranships the items to you. saves you paying the local distributors mark up and arse end of the world tax that we in this part of the world always seem to pay.
the brother had one so he could order things from overseas.
1 year 10 months ago #244838 by neil
What is the cost schedule for a service like that trainzkid?
Time to create page: 0.452 seconds
