Found a one owner 1950 D2 5U with 3940 original hours
Thank you received: 185
1 year 10 months ago #244130
by Markds3
Sme more progress over the past couple of days. Yesterday I cleaned the transmission out and finished cleaning the steering clutch compartments:
I also shrunk the bearing cones out of the caps using a bead of weld, worked really well!
gauntjoh
1 year 10 months ago - 1 year 10 months ago #244131
by Markds3
Today I pressed the new bearing cones onto the shaft and the cups into the covers and reassembled them back in with the shim packs exactly as they had come out of the tractor:
The rotational preload on the bearings landed exactly where I hoped at just under 50 inch pounds (allowing 10-15 inch pounds for the pinion):
Backlash landed right at .25mm (.0098 inch) (unfortunately I never checked this when I took the tractor to bits but if the shim packs are exactly the same as what was pulled out I'm hoping this is close to what it was):
And this is the tooth contact pattern:
This is the first time I have ever set up a pinion and bevel gear and would appreciate anyones input and advice if this contact pattern looks OK? Toby could you advise?
Last edit: 1 year 10 months ago by
Markds3.
gauntjoh
Thank you received: 657
1 year 10 months ago #244132
Seems a bit close to the toe although under load it should migrate outwards to the heel and also to the tip.
Markds3
1 year 10 months ago #244133
by Markds3
I trust Toby won't mind, but I screenshotted a still from his video of when he was setting up the Bevel gear and pinion on 5J1113 (which has a 5U gearset):
Do you think mine looks similar?
gauntjoh
Thank you received: 121
1 year 10 months ago #244148
by PhilC
Both of those look like short toe contact to me.
1 year 10 months ago #244157
I think those are half inch studs so online lookup says 30ftlb dry. I can't remember if I tightened mine with a torque wrench or just by feel
Markds3
Thank you received: 125
1 year 10 months ago #244161
by Sasquatch
I would be happy with that contact pattern, due to the drive pinion gear not being on an absolutely fixed axis because of the slight deflection caused by its ball bearing mounting, when load is applied to the gearset the contact will move upwards and land mid-range between toe and heel. The contact pattern in the still shot from my video runs perfectly quiet under all loads, even when we drug the RD-6 around with it until its tongue was hanging out lol
Markds3
1 year 10 months ago - 1 year 10 months ago #244162
by Markds3
Thanks so much for the reassurance Toby, interesting that the factory setup of shims has fallen exactly where I want it with no adjustments! Even with the new bearings. BTW your picture of from your manual is much clearer than my reprint! I also had a question re the 1/2" UNF studs and nuts on the bearing caps, what would you suggest these to be torqued to?
Markds3.
Time to create page: 0.435 seconds
