Found a one owner 1950 D2 5U with 3940 original hours
Thank you received: 125
1 year 10 months ago #244484
by Sasquatch
Excellent progress! You’re quickly coming down to the finish line of one of the worst jobs a person could have to do to a Cat D2 - my own personal least favorite job now is turning the pins and bushings - although doing bevel shaft bearings is only one notch above it lol 😂 The first drive will be well worth it though, when all the levers are adjusted well and you feel how smooth the clutches operate with everything in the back end being tight and right 👍
Thank you received: 185
1 year 10 months ago - 1 year 10 months ago #244488
by Markds3
Thanks Toby, I certainly appreciate your contributions and detailed help/knowledge. It's safe to say that your videos have inspired me, and I wouldn't have this little tractor nor would have undertaken this work with out them, so thank you!
And, to be honest, doing these bevel shaft bearings has taken much much more time and been far more difficult than I ever expected!
Last edit: 1 year 10 months ago by
Markds3.
gauntjoh
1 year 10 months ago - 1 year 10 months ago #244489
by Markds3
Today I got the seat and tank cleaned, lifted up and bolted in place:
I got the foot plates in place, fuel tank connected and the brakes adjusted:
And finally I got the pony running, fuel system bled and the main engine running!
Markds3.
Thank you received: 999
1 year 10 months ago #244493
by Rome K/G
Good to note and put in the archive's photos of those decals for correct placement on collector's tractors. Those are correctly placed on the machine from the factory.
Markds3
Thank you received: 506
1 year 10 months ago #244498
by Kurt Bangert
Mark, what are you using to clean the tractor as you go? The paint is exceptional.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
Markds3
1 year 10 months ago - 1 year 10 months ago #244519
by Markds3
Hello Kurt, nothing special, just a box store engine degreaser where there is oil/grease present. I'm going to give the whole tractor a wash with a car wash/wax to add some shine back once I'm finished. And you're right the paint is exceptionally good, very interesting to see the factory finish (which isn't that good in many areas!) quite a few runs and 'dry' bits where coverage isn't very good.
Markds3.
1 year 10 months ago - 1 year 10 months ago #244520
by Markds3
Today I hoped to have the tractor finished, but simply ran out of time as so often happens.
Started off cleaning the track frames, which I must say are in exceptionally good condition. There were several pounds of caked on grease/dirt mixture around each of the rollers and scraping it off the best I could took lots of time!
I then installed new pivot shaft seals with the lip facing outwards, as per the service manual:
Lifted the track frames in place:
And fitted the shims and retaining thrust washers with new fold over locks:
Markds3.
1 year 10 months ago #244521
by Markds3
I then started cleaning the rear rollers (which were removed to take the track frames off). While the bushes and shafts were in exceptionally good condition, three of the four bellows seals had split apart at the bellows. This also made it a real bear of a job to reassemble the caps back on the rollers without everything falling apart and I had to wire the caps to the rollers to hold everything in pace while installing them on the track frames. It looks like a project for next Christmas holidays will be to install new seals on all of the rollers!
Last of all I got the LH track looped over (all by hand, which is heavy work!) and the master pin hammered in place:
Thank you received: 657
1 year 10 months ago #244524
Looks good Mark. I have to say that it really helps when you start out with a unit that's already in great condition. You have a bit of a unicorn there and I'd say in your care it will stay that way - good job!
Markds3
1 year 10 months ago - 1 year 10 months ago #244548
by Markds3
Finally, after a long day of work I got her finished!
First thing this morning I got the tin work all clean:
And I noticed this silver paint brushed around the the underside of the exhaust opening, I can only presume it was from the silver paint brushed on the manifold from factory!
Tractor off blocks and tracks adjusted:
Just under 1 1/2" of thread clear on the adjusting screws with the tracks adjusted correctly!
Lifting the drawbar in place with a new ACMOC wear shoe:
Markds3.
Time to create page: 0.467 seconds
