- Thank you received: 0
Hi NIF 98J. Going back to augers .on the low side ie the lower half of auger does the crop ever refuse to travel to the feed elevator especially with different crops. do you have different revolutions to push the cropup and along to the elevator. thanks Atlas
tanker- still got some white stuff on the ground over there? .rub it in--
Main problem with the masseys is...well just about everything.
this global warming is getting me down:mad: - The `1155's round here were a can of worms also- pullers are all thats left cuz of the 640 eng-[most 640 are snaged from white combines] I needed something w/ 3 point to use rotary hoe & the 1130 seem to be the very best in that size- regardless of color-am wondering bout the peas you showed- do you combine after they are DRY? - peas grown round here are harvested by special combines the canning co has[if it says libby - libby - libby- on the label - label -label]- they have special combines for the sweet corn also..
Say whatcha want,, you cannot beat the beauty of those big machines with the "Radius Rod", "Torque Rod", or "Swing Frame" leveling coming around a steep hillside!!
Regarding Auger headers. When we got our first 95H there was almost no experience around with that kind of header. An old timer that overhauled our 36B every winter convinced us that little area between the sickle and the auger was not enough room to allow wheat to flow toward the feeder.
JD made an extension about 8" long (for what ever i don't know) which we insisted Frontier install.
Well we ran that for about halfway thru harvest and decided it was a joke. In fact it participated in igniting a fire. Also that year we had a lot of down wheat and that extension, because of the slope of the bottom pan, would not allow the sickle to get down below the down wheat.
We removed that POS and then we had a machine!!
98J- great job explaining the leveling details and adding the diagrams
Those are Jim's aka redpainter's pics of the 4 ways IHs im guessing from over in the Uniontown area?
Always thought the 4 way leveling was cool but in later years it was not that popular here, JD 95-H and 6602 machines had the market, gleaner was fairly common as well. The 70s vintage IH combines were nearly all used up and parked by the mid 90s while the 6602s are still cutting in fair numbers to this day.
support@acmoc.org
- Chris R
- Jason N
