Unfortunately I didn’t snap any pics of skidding logs like I said I would. Got too busy and didn’t want the camera to get knocked around while setting chokers.
I have some pics from the past couple winters logging on our own timberland. First so you don’t get lost here is a pic of the fields and the woods on the home place seen on the left.
Shot this in the afternoon yesterday still a bit of snow in the shade not much though
This is the same spot seen above except the date taken was April 3, 2009 so you see it’s a pretty mild winter this year.
Most of the trees in our woods are Douglas (red) fir also some Ponderosa (yellow or bull) pine, and a few white fir, tamarack, cedar, and white pine. The red fir trees have been dying from bark beatles which infect the trees in the spring and kill the tree by fall, the bugs then overwinter in the dead tree. In order to reduce the number of trees we lose we try to get all the dead trees hauled out and to the lumber mill by spring. This is done when it is frozen up so the muddy ground (mud underneath snow most years) isn’t torn up.
Going to be hauling this year’s logs out the next couple days with a small trailer instead of a truck so we left the logs in multiple smaller log decks instead skidding them all out to one spot.
The trailer that will be used.
First the trees are cut down, can be rather tricky in thick growth to get it down in the right spot, no problem here though.
Then you throw a cable choker around it and get to work with a cat.
Once a few logs come in they get pushed around with the blade to make room for more. I have seen the pro loggers just come into the landing at full speed and drive sideways onto the pile and drop them right into place.
When the logs are a bit on the big side, it is all the 2T D4 can do to pull them.
For the really big logs you get a bigger cat.
However just using one of the bigger cats you don’t get as neat of a log deck.
Here is a load of logs coming out a few summers ago on our neighbors self loading truck.
Now if you are logging big scale there is a whole arsenal of logging equipment to look at. Just east of here there is a lot of logging done, declining the past 30 years but still the top industry in this county.
Next few pics will be from a mountain about 30 miles to the east marked with a green arrow.
Fire lookout on top, still in use every summer.
Typical view of north Idaho.
You can see how some of the land is logged in a pattern of clearcut and regrowth.
On some of the steep stuff instead of skidding logs with a cat or wheeled skidder they set up a line machine on top of a hill. It uses a cable and high powered winch setup to run a mechanism with chokers on it (cant think of the name right now) down the hill along the cable at high speeds, a couple guys (known as hookers) are down there and set the chokers around the logs, give the line machine operator a beep and he pulls the logs 500-1000ft elevation up the hill and gets them to the top in about a minute. Trucks then come in and are usually loaded with 33ft logs.
They usually keep going all winter until the ground gets sloppy in the spring and then have a go at in the summer again.
This spot actually wasnt that high of elevation, only about 4,000ft but there was a ton of snow there in 07-08.
There just a little education about logging, way more dangerous than farming... easy to get injured or killed so just a couple days a year is enough for me. Just about everyone who worked in the woods full time had some major injury at some time or another. One neighbor who farmed and then logged during the off season was killed while falling a tree that pulled a small one down with it onto him from behind. A friends dad cut his arm off when a chansaw slipped, my uncle was hit by a rolling log, hookers get hit by snags, cat operators thrown off, logging truck drivers killed when log loaders slipped and let log falls off. Also while pushing the logs up into a pile there is alot of tension on them and they can spring up over the blade and wipe the operator off, not as big of deal with modern equipment.
All that hassle so that the nearby potlatch mill in Lewiston can make more toilet paper than any other place in the country
