D4D Rehab. project
14 years 10 months ago #39232 by d4c24a
Replied by d4c24a on topic recoils
i had to remove both of mine as the threads had seized solid on the adjusters
both of the locking bolts/rods had come out and the ends had corroded so i could not get them back in :mad:
i got them off in a rather unorthodox way ,but i was a good safe distance away
14 years 10 months ago #39242 by edb
Replied by edb on topic Roller Positions
Hi Richard,
here is a scan for roller positions for some machines.
Double click for larger size pic.
14 years 10 months ago #39270 by Richard~J~W
Replied by Richard~J~W on topic D4D Rehab. project
Graham,
Safe distance would be about right.....to have that up side my ear would probably knock me in to the next decade.
Ed,
Thanks for the diagram, that checks out with what I have.
BR
Richard
14 years 10 months ago #39272 by catsilver
Replied by catsilver on topic D4d
Hi Richard,
The rollers fit with the plugs in the shafts facing outwards, so you can remove them to see if there is any oil inside, don't leave the lock plates out, the shafts will move and fret in the track frames..
You can tell the the bolt sizes by the lockwasher part numbers, the last two digits denote the washer size in sixteenths, 3B4506 = 3/8", 3B4508 = 1/2" and so on, only use genuine grade 8 bolts or you will be in trouble next time round.
I've had no contact with Curwoods for nine years so don't know what their situation is.
I will try and post a chart of bolt sizes for you.
14 years 10 months ago #39275 by Richard~J~W
Hi Richard,
Excellent, thanks Catsilver.
Also there's the trans. belly pan bolt holes that need cleaning out - one is snapped off, in the parts book it's listed as being S-1595, looked in the One Safe Source book to see if its cross-refs but seems not.
It seems to be about 9/16 UNC.
edit: 1/2UNC....sorted
14 years 10 months ago #39282 by catsilver
Hi Richard, Cat use mostly 3/8", 1/2", 5/8" and 3/4" UNC on the D4D, they hardly ever use the odd in between sizes such as 9/16" etc.
14 years 10 months ago #39283 by Richard~J~W
thanks once again Catsilver.....appreciate the response(s) :)
14 years 10 months ago #39285 by Old Magnet
Replied by Old Magnet on topic D4D Rehab. project
S-1595 is a 1/2 - 13tpi x 1-1/4 long.
14 years 10 months ago #39308 by OzDozer
Replied by OzDozer on topic D4D Rehab. project
Hardware reference chart is on the Cat website. If a P/N has only a single letter, or only 3 numbers in the P/N, add a '0' to the letter, or to the number, to make up a "one-number-one letter-four number", combination .. i.e .. S-1595 becomes 0S-1595, and T-143 become 0T-0143.
This one number-one letter, four-number combination, was the standardised P/N format when Cat went over to computerisation in the 1970's .. and this format is all that the Cat system recognises, in the old part numbering system.
The new, current part numbering system of 7 numbers .. 3 numbers and 4 numbers, split by a dash, has been in use since the late 1990's, and is the only other parts numbering system recognised by the Cat computer network.
Hardware reference - www.cat.com/cda/files/87031/7/13_OSS_Hardware.pdf
14 years 10 months ago #39311 by Richard~J~W
Mr Magnet & Oz,
thanks for the replies :)
Time to create page: 0.242 seconds
