- Thank you received: 21
You can't recon the injectors, only test them, then throw away, if they spray OK and don't dribble, they are probably OK, if you have any doubts or they put compression gases back through the injector line, throw them away.
Good Luck.
Hello Richard, the plugs either side of the back end drain are in the steering clutch housings these are dry compartments. The final drives can leak inwards although a minor leak is probably best left alone as its quite a job to lift out the cross shaft and clutches. The final drives on your machine are better with 80/90 or even 85/140.
Regards Gordon.
support@acmoc.org
- Chris R
- Jason N
