D2-5U13753 - master pins - please check my understanding
Thank you received: 240
6 years 7 months ago #181767
by Mike Meyer
Looking great Neil, nothing like that first drive to keep the enthusiasm up, thanks for sharing the movie.
Mike
6 years 7 months ago #181769
by timbo1946
I know that it has been a while. You have made great progress since the first time we got unloaded and pushed in the barn
Thank you received: 663
6 years 7 months ago #181771
Well I tell you Tim, it's fought me every step of the way but I'm so grateful for all the help you've provided over the years. I don't think I'd be nearly as far along without it. I suspect the right side final might be slightly easier because looking in the brake access hole, the chamber's full of grease or somesuch so hopefully I won't have to replace everything, although I'm definitely going to do both hubs along with the clutch plates, because it makes the clutch operation so smooth it's like power steering.
Thank you received: 19
6 years 7 months ago #181794
Ha, yes it is - first prize to you! I told my wife I did that just to see if it would fit. I wish I could have video'd her eyebrow as it slowly gained elevation...
I have to take that track frame back off again to refurb - I put it on so's I could turn the tractor around to work on the right side - so I have a second chance to get it right : )
Thank you received: 236
6 years 7 months ago #182041
by d2gary
Looking good Neil. The hard work is starting to pay off.
Hopefully the the easy side is in fact easy. Nothing like a little spin in the driveway to keep you going
6 years 7 months ago #182262
Got the right side master pin out without damage. I have new plugs for it and managed to salvage one of the originals so it's reusable. Extracted two of the four bolts holding the pivot shaft cover on - two more to go with some heavy heating tomorrow. My 17t OTC 938 isn't moving the sprocket so I have a 20t ram coming which will hopefully be enough. It's a matter of the ram being thin enough to fit between the pulling bolts that screw into the sprocket. I'll remove the track frame tomorrow and then start working on getting the final assembly off.
I'm sure that adjuster nut will buff up nicely....
6 years 7 months ago #182295
by drujinin
Wrap that Puller up tight, then get behind the rearend and smack that sprocket with a Sledge.
It shouldn't fly too far when it pops free!
6 years 7 months ago #182298
Well, I cranked it pretty tight with a 24" crescent. Didn't stand on it but did push down with, I suppose, 150#. I'll tinker with it some more when Mother's car is out of the way. I'm sure two 5/8-11 Grade 8 bolts are good for 20t!
Time to create page: 0.473 seconds
