D2-5U13753 - master pins - please check my understanding
Thank you received: 59
6 years 8 months ago #180226
by hfdzl
Over the years I have also made all the adapters to push/pull with. Found my CAT pressure gauge the other day that I need. Has 4 scale ranges for various push/pull rams.
I am working on a 5E/22 tractor. Is there any specific specs for that model or would D2 be OK?
R2 5E3562 SP U.S.A. W.9151
R2 5E3563 SP U.S.A. W.9152
Thank you received: 663
6 years 8 months ago #180245
Showing my ignorance here : ) - what's a 5E? I have a 1J 22 and know of the 2F (Ray Puffer has one in Albany) but am not familiar with a 5E.
6 years 8 months ago #180248
Oh, I see - that keystroke came out e/22 - the back end on the D2s are pretty much the same so I think you can use any of the specs in the book that you find. I did make one change and that's to press the steering hubs on at 10t instead of 15.
6 years 8 months ago #180255
by hfdzl
Neil, should read 5E R2 same as 22
Herb
6 years 8 months ago #180262
Got it - yes, should be the same as the D2 specs for the J-series, which, in my Form FEO 30441-01 that covers both the J and U series serviceman's reference, the information is identical
6 years 8 months ago #180268
by drujinin
I don't know if I would press that gear on to 25 tons, let alone 20 tons.
Seems an awe full high tonnage for such a small part?
If CAT lowered the sprocket spec from 15 tons to 10 tons.
Then I would be thinking what's good on the outside is good on the inside?
Just my random opinion.........
6 years 8 months ago #180282
Well, I'm definitely not pressing it on to 25t. The splined area for the gear is a smaller diameter than the sprocket area, the hub area on the gear is thinner than the sprocket, and if I presume that the gear and sprocket are made from the same material, then bush logic tells me that the pressing tonnage for the gear should be less than that for the sprocket (which is 15t and I'm not even pressing that on that much)
6 years 8 months ago #180285
by hfdzl
Well just to answer this question I took a spare sprocket shaft and bull gear, not perfect factory new bore and mating surface, put them in in my big shop press- 75T. Pressed to 25T with no problem, turned around and took them apart, that was 15-18T to separate. I measured the distance that gear moved on the shaft and that was approx. .062. I think the two mating surfaces were not ideal. The taper is what holds the pieces together not the nut, that is there just to prevent things really getting loose.
My .02, i'm going for what Cat says.
6 years 8 months ago #180292
That's good information Herb, thanks for doing that experiment.
Time to create page: 0.422 seconds
