new member with a 1935 Cat 22
Thank you received: 25
12 years 8 months ago #61853
by 22Randy
i got a 12v 4.5-9psi today and it is running from under the tank through a fuel filter to the pump that has another fuel pump in it and out the other side i have plenty of flow...
I'm not sure what the psi of my pump is but it was too much for the carbs float and needle on my 22 because it would flood the motor sometimes. I added this adjustable pressure regulator and found a happy medium for the pressure and have been running the tractor this way for about 20 years now. If you find that your pump is too much, this might be another option.
Cat 22
Serial# 2F237
12 years 8 months ago #61854
by zootownjeepguy
Rich Salvaggio
D2 5U9917
The 2 most useful tools to have in your shop are a Crystal Ball...
12 years 8 months ago #61860
by lil cat mec
the carbs are on two different sides of the workbench, if the carb floods would the gas start to fill the intake tube? just wondering what to look for... thank you for the manual
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61862
by zootownjeepguy
If you have an Updraft carb (carb mounts under the manifold) it will just leak onto the floor unless the engine is running or you're cranking it. There should be a small drain hole with a check ball somewhere on the bottom of the carburetor to let any overflow fuel drain out. If the engine is running it will just fllood out & quit.
Rich Salvaggio
D2 5U9917
12 years 8 months ago #61864
by lil cat mec
ok now i remember seeing a spot that i'm assuming the fuel would drain if it over flowed.
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61911
by lil cat mec
i have the zenith k5a 7070a carb and i have only found one place that has a carb kit and there closed till tomorrow and napa didn't have any record in there catalog... were else can i look to compare prices?
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61912
by drujinin
Did you try the sticky post at the top that list tractor parts or the suggested places in this thread?
Most places sell fast moving items not antiquated obsolete carb kits.
12 years 8 months ago #61916
by lil cat mec
i don't know if it is me or my computer but i can't find the "sticky" that all of you talk about
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61917
by zootownjeepguy
At the top of the Discussion page are threads marked "STICKY:". The one at the very top labeled "Cat Parts Sources List" includes a bunch of sources for Cat parts. Open the thread and look for The Carburetor Shop. I'm sure they'll have what you need.
Rich Salvaggio
D2 5U9917
Time to create page: 0.265 seconds
