new member with a 1935 Cat 22
12 years 9 months ago #61484
by lil cat mec
looking at other forums i have read not to get the newer champion's do you guys agree with that
1935 CAT 22 2f4455W
CAT 951
12 years 9 months ago #61485
by drujinin
I have a theory that Champion has realized that there old tried and true insulator coatinngs WERE more susceptible to fouling. I am thinking that with alcohol based gas being dominant over MTB additive gas that fouling of newer plugs is less of an issue but the "Do not Use!" mentality is still out there.
Me?
I try to run off-brands or really old Champions but when I flooded my John Deere 2 weeks ago. I see that has some D21's in that may only be 15 years old which in my book makes them "New" plugs!
12 years 9 months ago #61490
by lil cat mec
also one question i had earlier is do you guys add the lead additive to your gasoline or just use it how it comes out of the pump?
1935 CAT 22 2f4455W
CAT 951
Thank you received: 6
12 years 8 months ago #61507
by ol Grump
Here in Oregon you can still get premium non-alcoholic gas at most stations. That's what I use in chainsaws, outboard engine, snowmobiles and the 4 wheeler. A bit of Stabil seems to help the storage life if I'm gonna store it more than a month or so before using it. Anything that's gonna get stored for more than a week, I run out of gas before putting it up.
Thank you received: 342
12 years 8 months ago #61524
by edb
these tractors were designed and built in the days before leaded gas/petrol was available. Also because of their low compression ratios they should not suffer pre-ignion etc. that later higher compression ratio engines do, the lead additive came about to stop this and allow compression ratios to be increased to improve power out put and fuel efficiency.
Back in the day valves seemed to last fairly well, despite no lead deposits to lubricate the seats etc. Maybe add a little bit of 2 stroke oil, and some Stabil as suggested by OG, would be beneficial to these old girls.
Others input appreciated.
12 years 8 months ago #61527
by zootownjeepguy
That's a big 10-4, roger, affirmative. Champion plugs seem to foul out fairly often in these older machines with low-compression engines. Go with Auotolite, AC or any plug with a Black Oxide base (not cadmium plated). Basically, if the plug has a shiny-bright base, stay away from it.
Rich Salvaggio
D2 5U9917
The 2 most useful tools to have in your shop are a Crystal Ball...
12 years 8 months ago #61557
by lil cat mec
well i finally got it back yesterday... it was $160 to get it rebuilt... nd it is just an old ac-delco starter... that the guy we bought the tractor from put on the back right above the draw bar...
i went ahead and ordered the w18;s so i guess i will find out if they work for me...
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61640
by lil cat mec
With the champion's that i already have should i keep the 3 W18's that are not cracked or broken, since i am getting 4 new W18's i was wondering if i should run it with 3 old and 1 new and just keep the other 3 as backups? or should i use all of the new ones? i cleaned the old ones up and it deffinantly helped now i have a verry bright blue spark
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61664
by drujinin
Put the 4 new ones in, then "Test" the old ones for problems after you get the tractor running good and reliably. You don't want to be troubleshooting misfire issues in the beginning. Then keep the good old ones for "spares".
12 years 8 months ago #61696
by lil cat mec
ok i put the 4 new sparkplugs in and now it doesn't fire at all... im thinking i might have hooked the plug wires up to it wrong... i have an american BOSH and how am i supposed to hook the wires up??? MAG # MJB4B-102
#1 Bottom right
#2 Bottom left
#3 top left
#4 top right???
please help the little boy lol
1935 CAT 22 2f4455W
CAT 951
Time to create page: 0.275 seconds
