new member with a 1935 Cat 22
12 years 8 months ago #61175
by lil cat mec
Im from washington state and i an 15yrs old...I have an old cat 22 that doesn't get any spark form the MAG and one of my friends ran the serial # on the motor... the metal plate with stamped numbers on it. and those numbers said that it was a 1965 D3 so im confused with it but it doesn't mean much to me i just want to get it running so we can do more logging with it... it hasn't ran in about 10yrs but pistons and carb are good... any info would help... thanks
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61176
by lyoncat
Hello lil cat mec,
Welcome.
The first/early 22s had a ser# 2F1 TO 2F9999 and the later models have their ser# starting with 1J1 to 1J5155.
Your friend may have misread the first two digits? good luck with your new project I'm sure you will enjoy the rewards your tractor will give you!
Mike.
Thank you received: 21
12 years 8 months ago #61179
by drujinin
You need to clean and or replace the points that are in the Magneto. Second thing is to replace the condensor that is in there also. If necessary a "will fit" is good enough to prove you don't have other issues in that Magneto. Third thing is the sparkplug wires need to be copper or steel, NO GRAPHITE NOISE SUPPRESSION style! Which name/model is the Magneto? There are several threads on here which you can use the "Search" function in the upper right of this page to access.
Good Luck!
Thank you received: 6
12 years 8 months ago #61181
by ol Grump
You might want to loosen the engine oil, tranny and final drive drain plugs a bit and see if any water comes out before going much further. Even if it was kept undercover, there could be some condensation in 'em. Better to be safe than sorry.
12 years 8 months ago #61231
by lil cat mec
i have already checked for water... it was not undercover it sat at our cabin under a tree and here are some pics...
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61240
by drujinin
Interesting that he says a 16yo tore it apart parked inside, he bought it.
You say it sat at your cabin under a tree??
So whats it the real deal?
Inquiring minds would like to know?
Jeff
Thank you received: 342
12 years 8 months ago #61253
by lil cat mec
my g-pa finally got it form one of his buddies and his buddie had it parked at our cabin:) so i am trying to get it running so we can have a work horse
so its not really mine yet... he put it in his will that it goes to my dad then to me:jaw:
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61255
by lil cat mec
and Jerry is just trying to help me out i had no idea that he used this forum as well
1935 CAT 22 2f4455W
CAT 951
Time to create page: 0.219 seconds
