new member with a 1935 Cat 22
12 years 9 months ago #61921
by lil cat mec
i got the wires today and cut them to fit and put the ends on them and all the do-dadas, and then i decided to compare the actual wire and i beleive the old ones were either 6 or 6.5mm because the newones were bigger including the silicone... but it still all fit...
ps just as a good long lasting paint, not a show quality paint what would you recomend? i will be using it on my case tractor not the cat because my g-pa is cheep... lol:lol:
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #62225
by lil cat mec
i got the kit today... and im starting to put it togeather and notice the idle jet (the long skinny peice) was broken and i was thinking well i can ask you guys... and then i notice the new float needle and seat was about 3/8th of an inch longer...HMMMMM so i called the Carb shop in eldon, mo and he said that that kit was directly from Zenith... so hes guess was that someone riged the float... so does anyone have a pic of the float? were it would meet the seat... and know were i could get the idle jet???
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #62341
by lil cat mec
does anybody have any options for the idle jet??? i really need a new one... tried soldering it and that didn't work... i ended up soldering the inside too...
I need HELP
1935 CAT 22 2f4455W
CAT 951
Thank you received: 6
12 years 8 months ago #62348
by ol Grump
John Deere used the same carb on the 720 and 730 Series Diesel Tractor, the p/n I show is AR 1309 R, Jet, Idle (sub for AZNR5R). Go to your local JD dealer and find the oldest parts guy at the counter for help
Seems like the price a year or so ago was around $19 or $23. .can't remember for sure.
12 years 8 months ago #62349
by boaterri
One more suggestion for carb cleaning. Soak the carb body in mineral spitits overnight, then use a cheep ultrasonic cleaner (Harbor Freight will do) with mineral spirits in it and run it outside for 10 minutes. You will find a layer of crud in the bottom of the container you soaked the carb in and more in the ultrasonic cleaner.
This was suggested by a mechanic working on 50 outboard engines/month all with the same problem, carbs fouled by bad gas. It worked well for me.
You can score some points with your mom by letting her clean jewelery in your ultrasonic cleaner using a different solvent.
Rick
12 years 8 months ago #62352
by ronm
OG, that number is AR13009, its a good number, $12.65 US at my dealer...they don't have one in stock...
12 years 8 months ago #62363
by SpragueM
Correct me if I am wrong but isn't this a carb from a model 22 ? I may have missed something along the way, I do not believe it has the same internals as the John Deere tractors. The carb form the D2/D4 starting engines are the same as the John Deere 720/730 starting engines.
Matt
12 years 8 months ago #62373
by drujinin
From the photo but a Ford Model A had a similiar type of jet in its Zenith. Google "Sacramento Ford" as they specailize in vintage cars and maybe can help you.
12 years 8 months ago #62396
by zootownjeepguy
LCM,
I'm heading down to the big antique tractor & engine show in Portland, In. on Wednesday. Get me the numbers off your Carburetor and I'll see if I can find a jet for you. Lot's of carburetor guys there usually.
Rich
Rich Salvaggio
D2 5U9917
The 2 most useful tools to have in your shop are a Crystal Ball...
Time to create page: 0.283 seconds
