new member with a 1935 Cat 22
12 years 8 months ago #61753
by 22Randy
what MAG do you have ???
I don't know if it makes a difference but mine is a MJB4A-104.
Cat 22
Serial# 2F237
12 years 8 months ago #61755
by lil cat mec
ok i will try switching the wires and see if that helps if not i will clean the carb put the wires on how they were check it then switch the wires again...
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61759
by rditz
with the choke all of the way on it wants to fire but with out the choke all of the way on it doesn't do anything... as in it acts like there is no fuel at all not even a pop...
do you have a little spray bottle that you can put some gas in and spray some in the carb when you are trying to start it?? this will eliminate whether it is fuel or not. if it starts and then dies, it is not getting fuel through the system, so you will have to work backwards from the carb making sure everything has been cleaned.
if all it wants to do is pop and sputter i would suspect that maybe your magneto is out of time with the piston position.
rod
12 years 8 months ago #61768
by lil cat mec
well i tried the plug wires the other way and not even a pop so i am going to put them the original way and i have no spark off the cyl 1 plug????? so i took the wire out of the mag and the wire was broken so i was wondering what size wires to get??? 7mm or 8mm??? or some were between... can i get away with 8mm?
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61777
by lil cat mec
is the size just the actual size of the wire or the wire and the silicone?
because what i've been told is that it's just the wire but i don't know for shure.
what i understand is if there is too much silicone then the wire will not fit in the mag?Right?
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61778
by Painter
That is the outside size, just be sure to get wire or copper core. Most auto parts sell it by the foot, most will say they cannot get it, but if they look in the catalogues they could find it
Hi, My name is Dennis, and I am a Rust-a-holic!
D4 7U17091 D6 8U10305 1926 Cat 30 1955 Ford T800, 74 Ford LT9000 1936 K Allis
12 years 8 months ago #61779
by lil cat mec
i am going to get them off ebay because they are cheeper than any autoparts store that i can find around here...
1935 CAT 22 2f4455W
CAT 951
12 years 8 months ago #61782
by lil cat mec
i just got her running i couldn't get her running for my life... so i have been trying all sorts of combos for the wires and what'da know the 1342 works amazing lol... she will even run on 2 cylinders...:lol:whoops i forgot to hook two of the plug wires up to it lol. now my problem is obviously fuel supply. with just a mist of ether she will humm like a pro. but without it it sounds like a dieing cat:noidea:
so i used an air compresser and blew it into the tank and forgot to pull the fuel cap so almost all of my gas is now on the shop floor lol, and i hooked all the pump and wiring up after i cleaned the floor and cat of the gas and still the same thing... i cleand every square inch of that stupid carb so now what should i do??? go back to autozone(i perfer them there nicer and have decent prices...) and get the other fuel pump?(higher pressure)
1935 CAT 22 2f4455W
CAT 951
Time to create page: 0.276 seconds
