- Thank you received: 18
Juiceman, please forgive my ignorance - I think you mean the leaking cross shaft seal would be leaking oil from the transmission into the steering clutch compartment? The right steering clutch compartment has a bunch of oily residue, both towards the inside of the machine (towards the transmission), and on the drum and brake band. I had attempted to wash the compartment with diesel as discussed in the manual, but not all of the diesel drained out, even after running it with the drain plug out. The left side compartment is dry and relatively clean, so I didn't bother washing it.My own observations with any U series D6, B model or D5 (basically same chassis) the seal for the cross shaft will seep right side first, contaminating that side. Flushing and generous dousing of the brake bands and drum with brake cleaner will usually help a lot until the back end gets opened up.
Is your helper pulling ALL the way back? If the engine isn't running with clutch and one of the selectors engaged? the booster will not be working. Armstrong required to pull back!
Neil: you like playing with fire! I would not dare test your poison oak/ivy trick!!!
JM
I don't think the hole is plugged. When I washed the compartment with diesel, I put in about 2 gallons and got probably 1 1/2 out of the drain. But the way the chamber is, there are two low spots that don't drain. It makes me wonder why the even recommend washing with diesel in the Operator's manual, to be honest!Try degreasing with some Safety Clean solvent or similar used in parts washers. That stuff removes oil and dries eventually and isn't too flammable but there is more flammable stuff too. There's probably a bunch of oil and dirt accumulated in the bottom of the clutch compartment just plugging up the drain hole. Run a wire or screwdriver up into the hole to open the drain.
If you can get it to drain well, Maybe try pressure washing the compartment. That is a messy job though.
Thanks Ray. I checked the ACMOC library - there is a scan of the D6 5R OMI. (Two scans actually - they look to be essentially the same.) What's in the library is nearly identical to what I got from Jensales. Definitely helpful!You're in need of the Operation and Maintenance Instructions. A small 1/4 to 3/8 inch thick book. The one in hand is a early one Form 12692-12( maybe more on the end) book is very tattered. But came with the last 9U D6 I bought. I keep forgetting you're working on 5R. I believe everything but the engine would correct if you cannot find a copy made for the 4 R or 5 R models. I know the steering clutch information would be correct. The other way to read it is to join ACMOC then read it in the online library.
Shop towels have been extremely tedious - there was a lot of fluid in there. I've gotten maybe half of it out that way.You could burn the residue off for sure and it's a variation on leaning on the brakes continuously to overheat the drums to achieve the same result. Definitely want pooled oil gone before trying it to avoid an actual fire, and you want to evenly bring the components up to temperature, being mindful of burning seals. I bought a cheap high-capacity syringe / oil extraction sucker from the web and it works great to drain out those undrainable pockets. Or you could throw some shop towels in there.
Another option is to use brake cleaner spray : ) to clean the brakes.
How much lining is left on the right side? Fresh is probably 3/8", worn out is probably a bit over 1/8-3/16 - just guessing. So long as you're not down to rivets, then clean, dry linings should work just fine
support@acmoc.org
- Chris R
- Jason N
