- Thank you received: 18
Wow, you are brave! I have also heard that ivory dish soap works well for this. Some people say you have to use cold water only - warm/hot water will open your pores and spread the oil further.Off-topic, regarding poison oak/ivy etc., I saw this video promising how to avoid poison x so long as you know that you were going to be exposed or did see that you got exposed. It's basically just washing the affect limbs with ordinary soap and a washcloth. The trick is to thoroughly use the soapy washcloth (like a good 30s of scrubbing the area) to remove the oil from your skin and if it's done within 2 hours of contact, you won't get poison oak. So, I tried it at my house and sure enough, it worked like a charm (and I get poison ivy just the same as most people). I grabbed some poison ivy in one hand, smeared it on my other arm, waited an hour, then washed it off using that technique - no poison ivy rash.
Thanks Busso. Others have also expressed a similar idea - it seems like the braces and tilt cylinders will want to fight each other. In practice, the blade will only tilt about 6-8".looking at the pictures would the threaded brace be required? I see there is hydraulic tilt cylinder (on the RHS only picture I can see) on the draft arm, my thinking unless your pushing material at the top of frame above blade the braces would not be required, (fitting tilt cylinder in that position would be better than brace and cylinder), tilt cylinders should be able to hold the blade at the set angle, these would have been fitted to help hold tilt angle while carrying a high load is my guess, the crack would be from movement up and down of blade fighting the tilt cylinders against the fixed braces as the blade does roll backwards on lifting as the brace would push it forwards , im not sure if I made sense???
Thanks Ray!The steering clutch adjustment is a job you do by brail if you don't have the fuel tank/seat removed. If the big cone nut turns you have it made (1 5/8 if I remember right ). I generally remove the small plate in the back as well. Helps get a second wrench in to loosen the lock nut.
The world is a large place. But Cat did not want to waste any of it. Most all the steering clutch and brake parts only have at most 1/8 of an inch clearance when pulling out of the case. Including the larger cover, needs to be tipped just right to clear the steering booster.
I did spot what I think is a pony motor air cleaner in the pile of 9u D6 parts. As there is at least one dismember pony on a parts tractor here, so I should have an air cleaner. I am not sure how close pony is on the 4&5R is to the 8&9U tractors.
The way I understood adjusting band-type brakes is to start with adjusting both the support set screw and the adjuster fork and nut to get "close", then adjust the set screw to the prescribed amount from the service manual - e.g. turn up tight, then back off maybe a turn to a turn and a half, then adjust the fork / nut to get the correct adjustment of the band, and then finally adjust the long rod to the pedal to get the pedal to the correct height. All of this pre-supposes that the linkage is firm and not sloppy. Lost motion from wear is an enemy of good adjustment. If your pins and yokes are worn, replace them and it'll be a lot easier to adjust.
Thanks Ray! I am brand new - had never been on a crawler/dozer before I purchased this project. I bought an operator's manual from Jensales - really useful, but it's frustrating that for some reason they omit the fluid capacities, which I believe should be on the inside back cover!I forget where you are on the learning curve, do you have operator's manual? The amount of free travel in the steering lever is the indicator the clutch needs adjusting. Start the adjusting by tightening nut 2B989 after releasing the lock nut., from the picture in this thread. I have seen many head ackees from adjusting the linkages rather than the clutch.
support@acmoc.org
- Chris R
- Jason N
