Restoring a 1946 Cat D6 5R
5 days 10 hours ago #260299 by neil
Replied by neil on topic Restoring a 1946 Cat D6 5R
Those measurements are on a new, tight machine. You most likely have worn linkages meaning the clutch levers will travel more distance to achieve the same result. At some point, the wear can be great enough that adjustment cannot be made effectively - you can go for fully disengaged but then slipping, or fully engaged but not disengaging (enough).
For bleeding, start at the source (the tank) and work your way forward methodically. Then go back and check again. If you have any new air after bleeding, then you have a leak somewhere. If it's between the tank and the fuel transfer pump, then you'll likely see the leak externally. If it's between the transfer pump and the injection pumps, then you might have worn components and leaking o-rings (usual reason on old tractors is that the seals lose elasticity and no longer effectively seal). Leaks after the injection pumps would be evident, other than if you have a defective injection valve that lets combustion pressure back into the injection lines - not that uncommon. So work though methodically until you identify the problem.
5 days 4 hours ago #260304 by JPiper
Replied by JPiper on topic Restoring a 1946 Cat D6 5R
Thanks Ray54!
I'll look in the toolbox for that wrench, but I'm not sure it's there. Based on pictures that I've seen, the rope might be original, though I don't know how it could be in such good condition!
There's a spring-mounted bolt that locks the throttle out when it's all the way forward, and I had the bolt set. But something is off with the throttle linkage (it rubs on the housing for the pinion engage lever and the starting clutch) - so maybe that has something to do with it.
2 days 35 minutes ago #260349 by JPiper
Neil - thanks for the info. Before I changed the fuel filter the machine was starting easily. Once I get the injection pump vent wrench I will go through the system step by step again, and hopefully that will take care of it! Unfortunately the wrench won't get to the tractor shop until this coming Friday. I also ordered replacement gaskets for the steering clutch compartments, and replacement gasket rings for the final drive fill plugs.
This past Friday was kind of a lost day. The wrench I need is not in the tool box. Looking around the property, I found a pry bar which could conceivably have been the original Cat one. I put that into the D6 tool box. But none of the other original Cat wrenches/tools.
I plan to go up tomorrow and service the diesel air cleaner. Depending on time, may try to adjust the right steering clutch. But likely won't be starting the machine again until this Friday or Thanksgiving week.
1 day 1 hour ago - 1 day 1 hour ago #260366 by JPiper
Serviced the air cleaner today. It was worse than it looked initially - thick sludge in the bottom of the bowl. But now all the screens and the bowl are clean, and it has fresh oil!
I realized, the poison oak infested D2 might have the injector pump wrench in its toolbox. Will check later this week.
eta: Comparing the parts book and the machine, I'm missing 8B340 (adapter), 8B342 (pipe), and 8B319 (air cleaner assembly). It looks like the machine was modified to add a second 8B347 bracket, with an aluminum plate across the two 8B347's, and the pony fuel bowl 3B8830 is mounted to one of the 8B347's rather than being suspended by a metal pipe from the fuel tank. I think this was done to facilitate adding an inline fuel filter (the machine has one that looks to be from a riding mower), with a flexible hose.
Really perplexed by what became of the original air cleaner...
Last edit: 1 day 1 hour ago by JPiper. Reason: udpate
15 hours 55 minutes ago #260367 by rhartwick
There was a thread on sources for the bleeder wrenches a few months ago. Search for "Fuel pump bleed wrench" and you'll see it. You can buy a 3/8" or 1/4" socket to fit the oval shaped bleeder valve without too much trouble.
2 hours 46 minutes ago #260385 by D4Jim
Replied by D4Jim on topic Restoring a 1946 Cat D6 5R
Good info from rhartwick.  Sometimes they refer to it as a (Double D oval) socket
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
2 hours 9 minutes ago #260386 by cr
Replied by cr on topic Restoring a 1946 Cat D6 5R
Here is a post from a while back for some options.
www.acmoc.org/bb/discussion-d72/32163-fu...bleed-wrench?start=0
The following user(s) said Thank You: JPiper
1 hour 7 minutes ago #260387 by JPiper
Thanks all! I ordered a 5P2682, and it should be here later this week. I found the part number on the vintage cat tools thread: www.acmoc.org/bb/discussion-d72/28472-vi...pillar-tools?start=0
Though the purist part of me would prefer the "original" 9F22 wrench. :)
Time to create page: 0.170 seconds
