- Thank you received: 74
Hi Scott,
Thanks for the video and update, it's great to see the progress you made with the D7. Again, you did a great job of conveying the information, some of which you've picked up here on the forum, to the viewers of your channel.
Compliments to Craig also. I don't know the man, but it's fantastic to see the generous and kind nature of some of the people in this club who go above and beyond to help out a fellow member and enthusiast.
theres always room for one more.no matter what she who must be obeyed thinks. ans getting the me working properly agian is half the fun.
and a machine with worn out tracks is fine if your only moving it on and off the trailer.
for something that you can tow around behind a regular vehicle you cant go past a d2. small fairly lightweight and very common. a u series machine is around late 40 early 50s for most of them.
d4's are a little bigger and 6/7u machines weigh around 5 tonnes wet. so you need a reasonable body truck to shift them. we personally have a d46u, (one day i will get it running again, must finish the conversion first.)
the bigger machines need a large body truck or a prime mover with drop deck trailer or low loader to shift them
paying to shift them gets expensive quickly but so does owning your own truck. what some blokes do is get a classic truck of similar or slightly newer vintage to the crawler to cart em round and they display the truck too.(in australia you can have the truck on the cheaper special interest registration(club rego) and use it to cart your antique machines to organised display events.)
or if your like juiceman who has his own business carting machinery and contract farming well the truck can be put to work on the weekends and during the off season.
Bulletpruf can test drive my used iron anytime LOL. Yes, seller should be very happy that you did your own "due diligence" . I have learned the hard way NOT to drive some stuff onto the trailer. The value changes quick when they see its making noise and moving on its own. It can be relatively easy and fun sometimes, but doing the dirty work for someone else at your own expense and then the balking about price can be a real turn off. I suspect you got a lot of enjoyment from your adventure, so its not always about the dollar.
I fondly recall a friend flailing his arms and running in circles when we pull started a D6 in less than 10 feet. At that point, he became very attached to it. Good grief, hahaha. JM
support@acmoc.org
- Chris R
- Jason N
