- Thank you received: 27
Sounds good, thanks for the input!Hi, bulletpruf.
It would be a pretty safe bet that this would be a 24 'jolt' system. Maybe get your lunch hooks onna set of fuel filters for it before you go - somebody more knowledgeable - and/or with a better reference library than me - may be able to tell you what filters you would need. Some fresh fuel might not be a bad idea either.
Thank you for your service.
Hi, and Thanks for your Service
Based solely upon pictures -
That D7 is going to need a lot of TLC - I would not expect to take batteries and either and 5 gallons of fuel and have it talking.
There are many items to check before starting - the clutch and attachments must be dis-engaged and free
The Canopy is definately not a ROPS - ROPS must support the entire weight of the machine.
Pictures do not show the exhaust side of turbo, do show open air cleaner, no hood, I would certainly recommend checking obstructions, debris in turbo
Be sure to check for breakage of the coolant systems. (water pump, radiator, block, etc) Look for damage to the radiator and oil cooler.
Water in Oil, etc. Ensure the fluids in the Fuel tank are not contaminated. Water does not agree with those systems.
Check the final drive and transmission oil levels and conditions.
Assess the condition of the idlers, sprockets, tracks - pins/bushings. (from pictures, track plates show grousers have been built up, pads show lot of wear, which could indicate rails-pins-bushings are worn out too)
RESCUE? Just takes TIME and $$$$$$
What do you plan to do with it, work, show, restore?
Good Luck
Good point on the wasp spray; I'll bring a few cans.yes it depends what you want. if it for just a show piece you can have 3 parts worn out track gear it only has to move on and off the low loader.
things to take if you want to revive her
fresh oil for the engine and trans (note some of these old girls have to be running to get a proper reading on the dipstick and read high when not running) a drum of each is a good idea.a 15w40 mineral oil is perfect for the engine.
fresh fuel and fuel filters. these generally will gravity bleed to the filters. they do have a lift pump to push fuel to the injection pump. a bucket to drain off some fuel from the tank and check for water contamination. there is a drain bung on the tank.
a decent hand torch
a borescope is handy if you have one to check the intake for debris if the piping is intact and the filter is intact then it shouldn't have a problem.
and dont forget a can of wasp spray they love yellow equipment it excites them.
support@acmoc.org
- Chris R
- Jason N
