D2 going in the shop
Thank you received: 236
3 years 6 months ago #228399
by d2gary
Mounted the fenders today.
Off to the radiator shop tomorrow.
With 4 to try to make one I'm hopeful but the guy wasn't really enthusiastic about working on but wanted to put a new core in my old tanks. I think there is one really good core and one that I would be ok with. I'm not an expert or in the business of selling radiator cores so we'll see.
Thank you received: 405
3 years 6 months ago #228404
by D4Jim
When the radiator guy drops the "good core" in the cleaning bath it won't take long to see if it is worth saving. Most of the radiators that I tried to have refurbished over the years all disintegrated in the first cleaning. Radiators are expensive as I replaced the radiator in an old 4440 JD to the tune of $3400 when all was said and done.
Hope your lucky rabbits foot is working and that you can use one of the old cores.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
3 years 6 months ago #228427
by d2gary
Well you called it D4Jim , he just didn't want to mess with the old cores. He picked the best tanks, which happened to be the ones from my tractor and said I can recore this one. $750 all said and done, ouch. Well at least I'll never have to worry about the radiator again.
Thank you received: 84
3 years 6 months ago #228444
by mog5858
very nice work. the rad guy was just seeing all that nice copper core and with them bring almost at 4.00 an lb right now I sure he will replace them all day long. help's to grow the beer fund. what the new core made out of? keep up the good work.
Thank you received: 321
3 years 6 months ago #228455
by Ray54
The radiators are not hard to work on compared to much of the other work you have done. I can understand time and wanting it done after the years you have spent. But save the old ones yet. About a day to CAREFULLY rod the crud out of tubes. I have had good luck tapping aluminum strip down plugged tubes. Some I had to start with brass welded all non fluxed rod, tap and pull tap a bit father in then move to the other side of the tube then go with a strip of aluminum. But the fan may have chewed things up. But if there is a chance they could be good with a rodding out they could be better than anything you can buy today.
Thank you received: 660
3 years 6 months ago #228463
A D2 fuel dipstick makes a good rodding strip although it doesn't go all the way through. If the hose is directed from the other end, then the dipstick is good for loosening up light crud "from this end"
Thank you received: 788
3 years 6 months ago #228591
soaking the core in a extra strong solution of laundry detergent such as omo for a couple of weeks may free up some of the crud then gentle application of compressed air to blow them clear you may be able to salvage them.
the rad service probably didnt want to spend the time and have you comeback later bitching that it leaks or cooked the motor and you end up costing him customers since you tell others about it. so yes they want to do recores and yes the price of scrap influences too
3 years 6 months ago #228597
by d2gary
The radiators were all pretty clean inside and came off of machines that weren't leaking. They also had bright green anti freeze in them. I will be getting the core back and the other two are in dry storage in my shop. I wouldn't hesitate to use them to get a machine "working " but just wanted something a little better for my rebuild. I have repaired and modified radiators in the past but again just didn't want to mess around and take a chance to have to go back and redo something that deep in the machine.
3 years 5 months ago #228761
by d2gary
Got a few more pieces on, almost to the point where I'll be waiting for a radiator and equalizer spring before I can go to much further. I still have a few pieces that can get paint and go on before I get stopped waiting for parts.
Time to create page: 0.456 seconds
