- Thank you received: 900
I L-O-V-E my D-6C. I am sure that I would love yours also!!!
Garlic Mom
Those are sealed and lubricated tracks, are the track shop going to reseal and lube them at that price? Have you actually measured the bushes to see of they require turning? To turn bushes in SALT track when they are not ready and not re-seal them is a waste of money.
Hi, Davo727.
I have only ever operated 2 D6Cs with straight dozer blades and could not see the ground behind the blade on either one. Trick - put the blade on the ground on a flat patch of dirt and pick a marker point on the back of the blade that you can see above the front of the track to use as a reference point for where your cutting edge is in relation to the ground. Over time and with practice you will likely get to a stage where you no longer need that reference point as you will know where the cutting edge is without it.
The D9Gs and Hs were the same.
cat@acmoc.org
- Chris R
- Jason N
