- Thank you received: 1
Sounds like your clearing operation was very shoddy ,and hap hazord ,if you keep the clearing neat by wind rowing or piling trees and stumps as your clearing ,so the machine is engaged to the land rather than traveling over trash ,also filling stump holes and keeping the land graded as you clear,and establish working room , things may have been different ,especially on hill sides . An experienced operator would have felt the root ball raising the front of the tractor ,and imediatly threw the tractor in reverse backing off as the root ball came up . Also this same experienced operator would have pushed the tree with the center or lower side of the blade so that as the root ball raised the tractor it would throw the lower side up keeping the machine more level throwing the tractor into the hill ,rather than down the hill
As to the engine .I would remove the oil filters ,and cut them open to see how much bearing material is deposited in the filters .If the filter are still clean you may luck out by hooking up a brake bleeder filled with oil under air pressure to the gauge line at the block and try to pressurize the oil gallary while barring over the engine to see if this will free up the bearing s ,and adjust the pony clutch as OM recomended
Hi dcrobira
Until all have operated a dozer on the west slope of the Sierra Nevada I can only hope that the criticism is tempered. I'm glad all is OK.
I have owned and operated crawler tractors since 1962 in all venues including 5 days on the Las Palitas fire in 1985 that nearly burned San Luis Obispo. I have found nothing as challenging as working a dozer here in the Sierra, where the granite domes rise up and take your tracks right out from under you without warning. I've ridden my D6C sideways 15 to 20 feet on a gentle slope that I would have never expected. New seat covers were ordered. It was a 10 on the pucker factor. Also the Buckeyes, Liveoaks and Manzanita combined with unseen boulders can high center a tractor with a 1/3 a turn of the track or less.
My neighbor was clearing several hundred acres with a 10K D6C. Was doing a nice neat job of a methodical clearing. While backing up a steep hill, the right track slipped forward, turned the tractor sideways and it rolled at least 8 full revolutions down through the brush. He said it was a slow roll and he thought it would stop three or four times but kept going. The ROPS held and seatbelt and helmet held well, though the ROPS had to be replaced before the tractor was put back in service. His biggest concern was having a branch spear him in his house while it was going over.
I hope that your repairs are not too costly and you are able to resume your work. Be careful and enjoy yourself.
Casey
support@acmoc.org
- Chris R
- Jason N
