- Thank you received: 0
Hi, Dcrobira.
Funny thing about these old jiggers - there is a li'l gadget called a decompressor on 'em which means yer don't hafta remove the 'squirts' to see if ther 'donk' is free. Ain't it juss wunndafull how inventive those designers were way back when?
I'd also venture to suggest that it might have run out of oil pressure running at that angle for 3/4 of an hour. I would not be too surprised either if there is some scoring of the cylinder bores and/or pistons.
Sad part about the whole thing is that, had anybody KNOWN what they were doing, it would VERY likely have reversed right outa there within seconds. Did you check the seat cushion for a mark that looks like a twist-off beer bottle top.
A kew-ree-yuss mind would like ter know.
"Dude, You're Screwed".
Jan
Hi, Dcrobira.
How full was/is the fuel tank?
Im trying to work out why your son left it running was there some reason in his thinking perhaps the pilot motor dosnt start any good dunno just thinking out aloud
If it is a dry clutch D-7, some old broken link trash may have fallen into the flywheel or starter pinion and jammed things so it won't turn.
In addition to the bottle top, there could also be on the seat a sticky, stinky mess transmitted from a pant leg over a very short period of time!
I'm with you on backing off and turning as you do so, however, if he was high-centered, the winch line would have helped that situation.
support@acmoc.org
- Chris R
- Jason N
