- Thank you received: 0
If the pony doesn't bog when attempting to start the pony clutch is slipping.
I wouldn't give up on starting it just yet. The three section oil/scavenge pump system should still be able to deliver oil at some pretty steep angles. Even if oil pressure was lost bearing freeze at idle would not be as severe as under load.
Bar it over a few more revolutions, tighten up the pony clutch and have another go. If oil pressure doesn't come up in reasonable time then shut it down and you know the task ahead.
support@acmoc.org
- Chris R
- Jason N
