caterpillar d6 9u
caterpillar d6 9u
10 years 2 months ago #113563
by stevens205
I have went to a lot of your guys profiles would love to see some pics of the cats you guys have!!!!!!!!
Thank you received: 78
10 years 2 months ago #113564
by dpendzic
I believe the pinion clutch lever if held in the opposite direction of engagement actually brakes the clutch discs. also changing the clutch oil out and filling with ATF oil helps with the braking. seems the pinion latches need tightening so they don't disengage too early.
D2, D3, D4, D6, 941B, Cat 15
Hancock Ma and Moriches NY
10 years 2 months ago #113567
by stevens205
Ya I know about the clutch break I will try switching the oil out and see if that helps how would a go about making the adjustment. Do I need to pull the starting pinion to do it?
10 years 2 months ago #113568
by dpendzic
not sure about a D6--on a D2 and D4 there is an access plate over the pinion latch mechanism to get in and adjust the latches--someone will jump in here that knows.
10 years 2 months ago #113585
by 7mileranch
Hey Gang,
Wonder why a Cable Blade? As Ed Akin says, "why no hydraulic oil on the ground!!! That's Why" !!!! Roflmao
I'll take a little dust control over cable sliver's and rat's nest's lol.
Thank you received: 826
10 years 2 months ago #113586
Same procedure for D2, 4, 6.
10 years 2 months ago #113590
by dpendzic
Pete--do you have something on the latch adjustment? I think that's what Stevens was inquiring about.
10 years 2 months ago #113598
Here is the adjustment procedure.
More often than not problems are due to wrong assembly or loose pinion sleeve or worn engagement latches.
Access is the square hole plug seen way to the right behind the engagement lever rod.
Do not allow pony to exceed 3350 rpm.
10 years 2 months ago #113744
by stevens205
thanks guys and thank you old magnet for the pic and procedure on how to do it. hopefully I can get that solved by this weekend before the weather changes. Thank you dpendzic Changing to atf solved the grinding problem instantly!!!!! not to mention the oil was milky more water then oil
still gonna have to do a latch adjustment will kick out when you take the compression release off and try to start so think it will be best to pull the whole pinion like the procedure old magnet posted to check the whole thing over. Thanks guys Stevens
10 years 2 months ago #113748
by 7upuller
Hey 7Mile,
"I'll take a little dust control over cable sliver's and rat's nest's lol."
The trick is to learn how not to make a Rat's Nest. You admitted that your "Young", maybe you'll learn, but some people choose cable rigs just for The Historical Nostagial Factor about it. Oh I own hydraulic rigs, and use those too, but when it's time to enjoy myself, I choose to run my cable stuff. I simply enjoy them. There is something about getting back into the history of it all. I think of how many miles and miles of highways that were built by cable set ups. How many cubic yards of dirt moved. It's amazing when you think about it. Some choose to laugh, they may not have it figured out, but don't look down at others because they choose to enjoy themselves. I think it's a nice '51 model. glen
caterpillar d6 9u
Time to create page: 0.205 seconds
