933f track loader issues
10 years 6 months ago #103286 by CHARLESCAT933F
hi all im new here i live in north ga and we have a lil farm
im working on a 933f i think serial is 42a1750
it has had some work done to it a reman head and alot of the undercarriage redone
i have been running it some and it sorta gets hot .the last time i used it
it blew the upper radiator hose so i stopped and shut it off
now it has a water leak coming from around the exhaust manifold area .i haven't had time to look at it
i did look down the thermostat housing and didn't see a thermostat .do i need one ? im thinking i do
and where do you guys think the water is coming from its in the middle of the head area that i can see by the exhaust
thanks for any help
also any help on where to order parts in my area would be great
10 years 6 months ago #103297 by Old Magnet
Replied by Old Magnet on topic 933f track loader issues
Yes, you need a thermostat, otherwise the water circulation rate is to fast to do adequate cooling.
Leaks in the exhaust manifold area could be leaking seal/s for the pre-combustion chambers, leaking head gasket or cracked head or block. I'd say most likely it's a leaking pre-com seal.
Check the list of sources posted above the discussion section.
10 years 6 months ago #103309 by ccjersey
Replied by ccjersey on topic 933f track loader issues
replace your blown hose and then put some pressure on the radiator with a hand pump or air compressor somehow and find your leak for sure. If your tractor is running hot without a thermostat, first thing to check is the radiator. It's very easy for one that old to be plugged up either on the outside so air cannot get through it or internally so the coolant cannot flow through enough of it to exchange heat.
One thing you might want to check if you find the radiator is fouled internally, you may be able to take the top tank off of the radiator with it sitting in the machine. Not familiar with the 933f frame to say if that is easy or even possible or if the radiator has the cast iron tanks that unbolt. Just something to consider, I've had good luck with a couple I've done. www.acmoc.org/bb/showthread.php?17111-D6...nd-radiator-cleaning
Another thing to check is if the radiator fan is installed the correct way around. Sometimes someone will flip a fan around trying to change the direction it blows and end up making it into a loud but ineffective fan that attempts to blow the same direction. A fan blade should discharge air to the side of the blade that is concave, not the side that is convex.
10 years 6 months ago #103314 by CHARLESCAT933F
Ok i did put another hose on it is leaking around the exhaust i seen it running out
I havent pulled it yet been working all weekend
ill get it off monday.
i did clean the radiator some outside with a pressure washer from both sides .it did have some dirt build up in one bottom corner
the fan blowes from inside the engin bay out threw the radiator i havent changed it .not sure on that one .
the engine is a D311 non turbo. Its like a d2 but with the d4 undercarriage
i did the white vinigar rust removal in the radiator trick
Left it in for a week .drained it then flushed it then refilled with coolent 4 gallons
the oil looks good no water in the oil
ill check the top radiator tank whill im there.
on the seals around the exhaust and the thermostat
where can i source these parts? Can i get old new stock
Thanks guys.
ill check thoes things asap and get back to ya
One t
Another thing to check is if the radiator fan is installed the correct way around. Sometimes someone will flip a fan around trying to change the direction it blows and end up making it into a loud but ineffective fan that attempts to blow the same direction. A fan blade should discharge air to the side of the blade that is concave, not the side that is convex.[/QUOTE]
10 years 6 months ago #103323 by ccjersey
There is no NORMAL gasket line or other joint that leaks coolant near the exhaust manifold. Only thing there is the head gasket line below it. You may have coolant excaping somewhere up top and running down to the exhaust, but the usual suspects (the precombustion chamber seals) are over on the left side of the engine on the opposite side of the valve cover from where you're seeing the leak.
One thing I ran into on the 9U I was posting about is the "freeze plugs" which seal casting sand removal holes along the top surface of the head. I was almost certain the head gasket was blown or cylinder liner seals leaking, but found the soft plugs were all rusted out and one was spraying coolant under the valve cover. On the 9U 6 cylinder engine, there are 7 of them and 2 separate valve covers which puts 3 of them outside and 4 under the valve covers. It's possible the very front and back ones on the D311 head are not under the cover and could leak coolant externally.
Not that an acid treatment won't help a fouled radiator, it will certainly help, but if the flues are plugged, there's no way for the solution to get to the scale etc. The first one I did was in a grader we brought back from the dead after it had been sitting out in the weather with the engine disassembled for several years. When we started to use if for the first time, it quickly overheated. I used a quart of muriatic acid in the 10-15 gallon cooling system and ran it until it got hot and circulated for a few hours. Still was getting hot after that treatment, so we took the top tank off and rodded out the flues of the core as I described on the 9U.
There was just too much rust and scale in there for the stuff to make much difference. Flues were plugged tight in many cases and not flowing much through most of the rest. I think the acid treatment softened up the scale and made it easier to move, so well worth the cost and time to do it even if it doesn't fix your problem. We ended up opening up over 80% of the flues without doing any damage, so we quit at that point and reassembled the radiator. Grader has performed well ever since.
10 years 6 months ago #103325 by Old Magnet
CC,
The 933F 42A1750 uses the D311H and the pre-com chambers are next to the exhaust manifold.
10 years 6 months ago #103326 by CHARLESCAT933F
Replied by CHARLESCAT933F on topic cc
thanks all this clears up some things for me .im going to pull the exhaust and the radiator
for sure
i hope its not a cracked head ,but my luck runs that way on most things
ill post up as soon as i find out what the real problem is
10 years 6 months ago #103338 by ccjersey
CC,
You're right, missed the swap from the old D311/D315/D318 with the injection pump on the left side of the engine. I have a 922B book which is with the D320 which is a turbocharged version of that D311H I believe.
Puts a 2H3088 o-ring around the top of each PC chamber right next to the site of the leak!.
If your leak is around those PC chambers, the whole chamber must be screwed out of the head to replace the seals. Top seal is an o-ring 2H3088 and then there is a soft copper or steel washer underneath the chamber where it screws into the top of the combustion chamber. Different thicknesses available to get the glow plugs to line up properly. 9H5897 is 0.104" thick and 8M3106 is 0.146" thick. I believe Eddie posted the procedure a few days ago. www.acmoc.org/bb/showthread.php?20598-31...ustion-chamber-seals
http://www.acmoc.org/bb/showthread.php?20598-318D-Head-Precombustion-chamber-seals
10 years 6 months ago #103340 by catsilver
Replied by catsilver on topic 933f track loader issues
If you leave thermostat out on most Cat engines, and the 933F is one of them. it is guaranteed to overheat, the 'stat opens the top hose to the radiator, but also closes the by-pass line, with no stat. much of the water by-passes the radiator. The first item to fail on these smaller engines when they get too hot is the O ring seals on number 2and 3 combustion chamber.
10 years 6 months ago #103344 by CHARLESCAT933F
wow if that's all it is, its a miracle i never would have figured injector glow plug washer
and you know i was looking at the injectors when i seen some water but i figured it was from
me spilling water as i filled the radiator
any chance on getting a part number for the thermostat? anyone have old manuals
i live in north Georgia i think there's a cat dealer in Dalton
unless i can get these parts anywhere else?
i haven't had much real time working on diesel engines so finding parts even with part numbers should test my google fu
wow this a relief
you guys are awesome
thanks all
1962 traxcavator sn#42A1750 933f d311h
Time to create page: 0.406 seconds
