My D2 Project
My D2 Project
10 years 9 months ago #101293
by restopat
Got the gauge cluster blasted and repainted as well as the switch and light cover. New stuff is all 12v. Starter I've always used on 12v. Generator wasn't hooked up and regulator was gone. What do you guys suggest convert to 12? Want to get the guide lights as well. Went to change the fuel filters and broke two of the fiberglass rods........ yay... rad cap came in today. One step closer.
Thank you received: 13
10 years 9 months ago #101296
by Cysco
restopat,
I had the generator on my D2 rebuilt and it is still 6 volts as are the lights. The pony starter was rewound for 12 volts and it is independent of the generator and lights. No particular reason for leaving the generator 6 volts ....just had everything to do it that way.
Everything works well.
Have a good evening.....Bill
Thank you received: 276
10 years 9 months ago #101299
by rax200
last year i rebuilt a 6v delco generator for a friend in to 12v, but with this it you will sacrifice current, if it is a 6v 19 Amp gen it will become a 12v 10 Amp approx. What you need to do is replace the field coils with 12v ones with the same rotation, the armature you do not have to change as it will on 12v, you will also have to find a 12v regulator with a max current of 11 Amps (i used one of a harley) but you can use another one but you have to have readjusted to 11 amps.
so you have to forget about the 200 watt driving lights
www.acmoc.org/bb/images/icons/thumb.gif
I have all the part numbers listed at home if interested.
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 240
10 years 9 months ago #101325
by Mike Meyer
You are doing a great job there, thanks for sharing the journey with lots of photo's. I'd suggest you also check the thermostat before you start painting the Highway Yellow top coat, on all my old Cats they have been either missing completely or jammed open, an extra 10 minutes work is definitely worth it at this point.
Keep up the great work.
regards
Mike
10 years 9 months ago #101365
by Jw74
Looking great. Its encouraging to see your project coming along thanks for sharing
Thanks God Bless
10 years 9 months ago #101366
by Jw74
restopat,
Cysco, your D2 is looking incredible how long have you been working on it ? And what have you restored on it?
Thanks God Bless
10 years 9 months ago #101381
by restopat
Thanks for all the info and compliments! I think I will keep it 6v then. Will make life easier. Now all I need to find is those guide lights.
Cysco....Now that's how a d2 should look! Hopefully by the end of this thread I get a result like that!
I did pull the thermostat. Next step is going to be to pressure test the radiator. The old cap I had on there was non pressure so I'm a little concerned that the rad core might not be up to snuff. I finished up the gauge pod last night. We will see what I can get done today after work.
10 years 9 months ago #101417
by restopat
Thanks! They do look pretty smart for being dirt cheap.
Got the dif cover back on. Used new lock washers, gasket, new corks in unused threads, and cleaned up the serial tag. Filled up the pony engine with straight 30 with a zinc additive. Installed the new fuel gauge. Blasted and painted the shift selector housing.
10 years 9 months ago #101424
by Jw74
Looking Good Restopat, where did you get your gauges I need the same thing on mine and what did you have to pay for them? Thanks, Jesse
Thanks God Bless
My D2 Project
Time to create page: 0.209 seconds
