My D2 Project
10 years 9 months ago #100826 by restopat
My D2 Project was created by restopat
Hey there,
I'm new to the forum and have been using some of these threads as invaluable resources so I figure I would post a few photos of what I am working on. I have a D2 5U, not sure of the year but I can get the serial number off it if I can remember tonight while I am over there. I have already done the main clutch and clutch collar in it. I bought it as a non steering unit and the clutchs are locked right up so that's what sparked this whole gig.
I know one of the things I'm going to be looking for is the drain plug for the bellhousing which is missing as shown in one of the pictures. This allowed mice into the case to build a nest and destroy my main clutch colar prior to me buying the machine.
Let me know what you think!
10 years 9 months ago #100827 by willitrun
Replied by willitrun on topic My D2 Project
we're talking about some serious ambition here. great pictures
10 years 9 months ago #100828 by neil
Replied by neil on topic My D2 Project
Awesome Pat, the harder the project, the more I like it! For the bell-housing drain plug, you can get them new I believe, as well as used. What's the jig in picture 17? Looks like an engine leveler but seems too short. Also, what happened to the final drive casing on those couple of bolts? Just curious because I have to pull mine at some point and would like to avoid the damage if I can.
10 years 9 months ago #100832 by restopat
Replied by restopat on topic My D2 Project
The jig there is a product of the lack of steering. I was not able to get the track in a possition where I could get at the master link on that side. I built that quick to be able to lift the undercarrige off the ground without hanging up on the track. I engaged the diesel to the pony and spun the pony over by hand to the track master link was where I could get at it. I realized after I built that thing that a simple bar with bolts on the end would of suficed. The learning process at 10pm haha.
The two chunks out of the case was me prying against the case to free the final drive from the steering clutch. The drum was hopelessly stuck so I used an impact chisel to break the outer drum so I could get the final drive off.
Gotta keep motivated! Did this work over the past 10 nights and weekends. I have to get the water pump off, generator, and the left side final drive off. I think thats as far apart as I will need to take it. If I can find some exhaust manifold gaskets I'll pull those off and repaint them.
10 years 9 months ago #100836 by Garlic Pete
Replied by Garlic Pete on topic Nice work.
Very ambitious, especially for ten nights and weekends.
What happened with the master link? It looks like you cut or chiseled the end off, if I'm interpreting that picture correctly. I don't think I've seen master pins with those sideways pins or plugs in them, or maybe those are something you put in in the removal?
Unfortunately, your experience with the broken brake drums, and attendant risk of breaking the final drive case, is a common one with the D2s. It looks like you did good with getting the one apart. Good luck with the other.
When I'm planning to work on D2 clutches, I try to work them back and forth to break the clutches free as much as I can stand it before I try to take them apart. Often they won't break loose, but I think the work helps to get the teeth on the disks working within the drums, breaks up some of the accumulated crud and lessens the likelihood of a broken drum when disassembling the final drive.
You'll notice that there is a lot of crud and scale accumulated in the grooves inside the drum around the protruding teeth of the clutch disks. This is what locks the drum and disks together and leads to the broken drum. Most of the drums I've seen even have little hollows worn into the grooves where the teeth run, further complicating disassembly when the clutch disks can't float.
When you get the drain plug, make sure that you drill it about an 1/8" larger than a big cotter key, then insert the key and bend it so that it will rattle around loosely. This allows condensation and moisture which inevitably makes it in the top of the compartment out the bottom. A completely sealed compartment can cause almost as much destruction with rust, corrosion and moisture damage to linings as the mice did! You should do the same for each steering clutch compartment.
Keep the pictures coming and keep up the good work.
Pete.
10 years 9 months ago #100848 by Rome K/G
Replied by Rome K/G on topic Fire?
Looks like a time bomb there with #1 ash tray #2 fuel line #3 cigar lol looks like a project! once you get it all cleaned up and new parts she'll operate like it should. Have fun, be safe.
10 years 9 months ago #100858 by cr
Replied by cr on topic My D2 Project
Since you have gone that far I would drill the bell housing for direct start. Even if you don't want to put a starter in there now you can put a cover plate over it and you will thank yourself later.
10 years 9 months ago #100863 by neil
CR, that's a good idea. I have the engine out of my 3J. I guess it would be pretty straightforward to have someone drill it.
10 years 9 months ago #100866 by restopat
Haha yea I moved the cigar shortly after.
I will look into drilling for the starter. This pony engine setup is one of the reasons I love this machine though. So I doubt I would ever convert it but your right you never know.
Below are some photos of the little I did last night. Stripped off the water pump which has a bad bearing, the generator, fuel filters + fuel pressure gauge, and the oil filter assembly. The previous owners would always run this machine with hose water then drain it out after every use. Not sure what the best method to clean out the cooling system is but sure looks like it needs it.
10 years 9 months ago #100868 by restopat
Speaking of things to do while I have it this far apart.... What else if anything should I take off, clean, check, rebuild, etc? I want this to be a one time deal haha.
Time to create page: 0.224 seconds
