- Thank you received: 0
Just curious. Did Caterpillar ever equip their ag tractors with factory PTO's or power take offs like wheeled farm tractors??
Yo Art!! No clue about the make of the small combine in the brochure. Did a little digging around on Google & came up with a little tidbit ......Deere's answer
to the A.C. Model 60, was the JD NO. 6, built in 1936 that had a similar cross
wise threshing set up.....spike tooth cylinder, on rubber, PTO or engine power.
Wonder if it could be one of those???
Not to side track this thread but Tanker I have to ask about your steering clutch controls are these of your design or are they after market?
Got the hyd stearing off my spare 2U- don't know where came from or what brand-- had the pull handles like on a factory 46A- they pulled to hard so I modified with the upright levers which suited my app [ie seat ht] much better- and can be pulled w/ ease- the master clutch is mounted on ball bearing set to cab floor w/ drag link underneath- = reverse action like our old A JD.. brakes pedals each go to master cyls & lines to slave cylinders made from landing gear cyls from p38 lightning-converted to brake fluid instead of hyd oil- tranny shifter & johnson bar/ shuttle lever come up through floor.
In the black and white picture on the previous page, are you sure that is a Caterpillar? Look closely at the 'tented' hood, and the lettering on the radiator, at least to me, looks to be Cletrac.
Also, while that is a sack type combine, the piles showing in the picture do not appear to be sacks of grain, but, instead, they appear to be piles of straw. I am thinking this because all the pictures I have seen, and they are very few, the sacks are white, and there does not appear to be any windrows of straw behind the combine in any of the swaths showing in the picture. The combine does have the sack chute on the side, but I cannot see where the person who fills and ties the sacks is setting.
Again, thank all of you for the beautiful pictures. The scenery does help, but having the creativity to take a picture that is fascinating and well composed makes it much more interesting than a mere 'picture'.
I do not know if you are aware of the massive thread on the Red Power Magazine "Coffee Shop" board, about the IH Tractors on A Montana Farm, which has over 300,000 views, and has expanded into many topics, from Steam Plowing Engines, to grain elevators, to Model T Fords, but it is a very nostalgic and interesting thread.
North Idaho Farmer: Thanks for the elevator modification pictures and the other combine shots. I like the looks of the elevator on the 80 machine, kind of reminds me of the old 95H setup. On our two machines we had all of the auger edges hardfaced. Helped out with the wear considerably. Hillside operation does tend to stress the frame components. looks like your mod's are holding things together. On the new hillside conversions I like the Accu Level or the old Racho conversion the best, seems to be a lot stronger than the Hillco. No doubt its more expensive. I have never looked at a Hillco in the flesh, must be a reasonably good unit, lots of them around, seems to be the conversion of choice for the Case IH machines. The days of the old water can sensing, or the mercury board level sensing are gone, there doing all that now with a computer sensing the level. They tell me it works like a charm, faster, smoother, and you can trim the header beyond max level. In certain spots I can see where that would be very helpful.
Great Pictures, nice country you have up their.
support@acmoc.org
- Chris R
- Jason N
