(pictures) farming with steel tracks
14 years 9 months ago #40620 by Member2103
Replied by Member2103 on topic Pto
Just curious. Did Caterpillar ever equip their ag tractors with factory PTO's or power take offs like wheeled farm tractors??
14 years 9 months ago #40621 by North Idaho Farmer
Bruce and Darrol- nice pics look forward to seeing more.
Jim- on the old model 35 which had a 30 inch wide seperator compared to 36in on the model 36 (the width of the 36 may be different but thats what I remember) they ran a 14' header on it and actually cut a 76bu crop with it one year around 1960. (that was considered an unbelievable yield back then)
member2103- no I never heard of any PTO on them
14 years 9 months ago #40623 by cr
Member 2103 Yes cat had an option for PTO's on the D2's, D4's D6's and the gas tractors, but I have only seen one out here on a d2 in the California delta running a lift pump. Heck we don't even use the PTO's on most of our wheel tractors.
Here are some California equipment
Deere 9520T pulling a 6 bottom Wilcox plow on already subsoiled ground.
Cat D6C 17R pulling AC 600 subsoiler & Schmiser ring roller. Typically pulled in 1st gear 1st pass at 18" - 24" deep second pass usually 2nd gear and 4" -6" deeper than first pass.
D5B in background with custom ditch closer / ridger, fore ground Oxnard GWO 12' stubble disc, pulled by a D6C / D6D in third gear. Challenger 55 can't pull this at full depth in heavy clay.
CAT d5 21j pulling IH vibra chisel and schmiser 16' ring roller.
D7 discing peat/clay. currently 8' below sea level.
14 years 9 months ago #40625 by 98j
Yup. Had one on my 7U......cut a lot of hay with it running a JD No. 5 mower.
Here is a shot of a PTO on a D2 running a mower.
In this shot, the Holt combine being pulled by the D2 has it's own motor, but the smaller combine in the middle & the spud digger at the top are both run
by PTO from the D2. The unit I had on my 7U was a two speed set up.
14 years 9 months ago #40626 by 98j
"Ill try to throw in a few more pictures, here are some of our combines as I have to get that image of that red combine that 98J posted out of my head."
- NIF
Gee whiz, didn't mean to give you a case of apoplexy .....:rolleyes: :rolleyes:
Only fair, since it's your thread, that I post something for you to wash your eyes out with, a little tonic to sooth a wronged Green Paint man.........a 9760
STS , Hillco equipped, belonging to Kortge Wheat & Cattle near The Dalles, Oregon, July 14, 2009 ;) ;) :cool:
14 years 9 months ago #40627 by 98j
More steel.........D6B seeding w/ double disks..........
My D5 SA hooked up to a JD 40' rod, rooting out some weeds prior to seeding;
14 years 9 months ago #40628 by 98j
A 7U D4 (late model 5 roller track frame) pulling a IH model 51 Hillside combine.
( that's yours truly at the controls) Pleasant Ridge, SE of The Dalles, Oregon
circa 1970.
:cool:
14 years 9 months ago #40629 by tanker
My 20 has pto- was used to run corn picker & sugar beet digger- county had 2 ea slide bar D8'S W/ PTO-- I made a pto setup on my 2U for 1000 rpm- dark now but will fetcha pic tmro--
14 years 9 months ago #40630 by Darrol D8H
Replied by Darrol D8H on topic Mt765
Atlas: the challengers turn better with load. Also use tehem in row crop work.
14 years 9 months ago #40631 by North Idaho Farmer
CR- nice pics, interesting to see that equipment being pulled that is completely different than anything we have. I assume that is irrigated ground, what crops are grown? Are there many steel tracked cats still running in that area?
98J- thanks the green and yellow paint helped :) I dont mind a few red ones though I was just giving you a hard time.
I was wondering though, I realize most of the cat pics you have are a few years old. Out of those cats in your pics (D5B, D6C, D6B, older D5 with JD plows) how many are still running now? No-till looks like the way to go in your area as your crops appear to be outstanding and there would be a definite savings on tractor hours/diesel.
Time to create page: 0.468 seconds
