D7 3T pony motor not starting
Thank you received: 502
1 year 5 months ago #248526
by ctsnowfighter
Good News
Perserverence pays dividends!
Dozer raises by itself? Hydraulic or Cable?
If cable you most probably have a sticking clutch, need to check to clean it up and adjust. Something you should do before you tackle the right brake and oil cooler.
You do not want to have dozer reach limits and pull something apart.
CTS
Fat Dan
Thank you received: 64
1 year 5 months ago #248527
by V14
It's CCU double barrel rear winch, need to figure out how to get some cable for the rear winch portion since it has none. Yes that will be a priority though, had to move a tiny bit then stop let the blade back down then move some more just so it wouldn't keep trying to pull up while maxed. It wasn't doing that when I went to look at it before buying though so maybe something got stuck or knocked loose when shipped. I'll try and grease it first before pulling the case open.
carb will be rebuilt this weekend kit is out for delivery then i will figure out the oil cooler after those two issues are solved. The brake works still just very sticky doesn't want to push in easy or return but is still usable so that's the lowest priority but all of these will be fixed before any work gets started.
1 year 5 months ago #248529
by ctsnowfighter
Cable Control Unit - CCU is not the same as a "winch" in terminology
Look on the "unit" for a tag and then find the operators/parts manuals for that attachment.
Typically, CCU was two drums for operating a cable unit scraper or using a single drum for the dozer.
CTS
Fat Dan
1 year 5 months ago #248530
by V14
I see. Well I'll be ordering the manual for the CCU tonight just have to run outside and figure out the model in a bit.
Fat Dan
1 year 5 months ago #248532
by V14
I looked all over the ccu and there is no identification at all. What was interesting is that there is a serial number plate on the back left under the ccu that says 4t but the one on the engine says 3t.
Fat Dan
1 year 5 months ago #248536
by ctsnowfighter
Pictures help a lot - Post Pictures of the CCU
Many here with much better knowledge than I on the Model #s, etc.
Nothing says the engine could not have been changed.
CCU - may or may not be Caterpillar -
Fat Dan
1 year 5 months ago #248537
by V14
It's a 25 model CCU already ordered a manual for it. I was thinking it may be a 4t with a 3t engine swapped in after seeing that. Not really much difference between the 4t and 3t from what I have seen browsing this forum.
Fat Dan
Thank you received: 276
1 year 5 months ago #248542
by rax200
There is a no 25 course manual in the technical library
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Fat Dan
Time to create page: 0.414 seconds
