D7 3T pony motor not starting
Thank you received: 64
1 year 5 months ago #248952
by V14
For sure 1k for a carb is not in my budget. I'll figure out a way to make this one work after I get that screw replaced.
Thank you received: 788
1 year 5 months ago #248970
by V14
It's actually new not rebuilt there is a rebuilt one on ebay for 700 but that still high for a refurbished. Just the few choke parts I asked about were 250 through that place so they probably just mark everything way up.
1 year 5 months ago #248976
those screws should be sae threads. any decent fastener shop should be able to source screw like that take the shaft with you. once you get the butterfly centred in place a drop of loctite 290 or permatex afterlock on the thread will keep them in place. you can also use a drop of starbrite liquid electrical tape.
try your cat dealer. the parts book should have the part numbers you need. try search those part numbers on parts.cat.com if they show a listing then generally the dealers can supply them.
a google search is also your friend if you can find the national stock number for the carb you can find what else it was used on and you can have more luck that way i guarantee these carbs were used on other brands of equipment.
V14
1 year 5 months ago #248979
by V14
I ordered them already was just hoping the hardware store would have a match so I could get them right away but wasn't so lucky.
Thank you received: 186
1 year 5 months ago #248980
by josh
Does this look like the top of your carb with the choke parts? 7F3838, was looking through my stash of junk, I mean good used parts, and came across this.
1 year 5 months ago #248981
by V14
Different part number but same zenith 22ax8 carb so should be the same.
1 year 5 months ago #248982
by josh
Do you still need the parts? I was thinking of trying to take it apart, the screws are soldered in to the choke plate, but it appears that the whole top assembly could be used instead of swapping parts, let me know and I can clean it up and see if it's useable.
1 year 5 months ago #248983
by V14
Sure I'd be interested my choke lever is still an issue so swapping could help. I have the ultrasonic cleaner now so cleaning shouldn't be an issue. Send me a message with what you are looking to get out of it
Time to create page: 0.418 seconds
