Wont start
Wont start
Thank you received: 502
1 year 3 months ago #250276
by ctsnowfighter
Easy Mistake - IT DOES SAY "START"!
I think many of us have been there at one time or another. Crank an engine and find you failed to check the gas! The switch was off or it had been wet and grounded out.
Anyone around a "screaming jimmy" that has had trouble starting it then look to find someone pulled the emergency stop? That little tin flap over the blower makes a huge difference! (I have seen mechanics overlook that one.)
"keep 'em crawlin'"
CTS
wanglow
Thank you received: 774
1 year 3 months ago #250277
by juiceman
Congrats on getting it running. I had a similar situation; the throttle rod was not connected on mine (hidden under hood) previous owner used all thread, and when tugged on, it sounded just like the ratchet for the governor, except it did not have quite the right feel. quite embarrassing and funny for me. JM
1 year 3 months ago #250279
by ropot
Wow!!! A big thank you. You're the hero of the discussion boards today. The confusion had always been, what direction to move the lever on the governor. It was loose when I got the dozer. The air cleaner is off, so I have no throttle yet at the operators station. The manual is a bit unclear. I had the gov closed. I slammed it counter clockwise and is started right up. Performs great. Now, I can put it all back together. (once I un stick the drive clutches). Your suggestion was just what I needed, and exact on! Thanks!
Thank you received: 788
1 year 3 months ago #250281
yes and the seat lever works the other way. as its a single stage linkage not a double. but its where the saying "to the fire wall" comes from.
Thank you received: 121
1 year 3 months ago #250286
by PhilC
You pull the handle towards you to increase the revs on the D6. You push it away from you and pull out a detent button to shut it down.
Wont start
Time to create page: 0.167 seconds
