d4 7u17432 transmission issues
1 year 7 months ago - 1 year 7 months ago #247586 by Deas Plant.
Hi, dfelct1.
If you make it to Margarita. there's one guy who'll be there and from whom you need to steer well clear. He usually hides inside a bright lime-colored Hi-viz shirt. He's bad news six days a week and worse on Sundays.
Rumor has it that he'll be there all 4 days - - - and all 4 nights. He is apparently part of the furniture on the ranch.
Last edit: 1 year 7 months ago by Deas Plant.. Reason: Add Info.
The following user(s) said Thank You: dflect1
1 year 7 months ago #247587 by dflect1
sounds like he will be easy to spot!
1 year 7 months ago - 1 year 7 months ago #247588 by Deas Plant.
Hi, dflect1.
Be careful. He may be hiding in some machine in the sand pit just waiting to ambush somebody.
1 year 7 months ago #247589 by juiceman
The case seal made of fiber material or cork is very expensive; an alternate someone tried was rubber rope, same stuff used for making snubbers for a truck tarp.
Just trying to help you save a lot of money for so little stuff.
Hope to see you at SM too. JM
1 year 7 months ago #247600 by rax200
Hi Dflect1,
The seal 3b889 is a 3/8 by 3/8 cork gasket about 3 feet long, 2 required, and the price is well overpriced, so I used a piece of 8mm round nitrel cord about 2m long and cut it to length. You have to use a glue compound to stick it to the lid before installation of the cover.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
1 year 7 months ago - 1 year 7 months ago #247602 by trainzkid88
nitrile oring material would probably work very well. and a few dabs of tarzans grip or bears contact adhesive would work just nicely to hold it in place. you could also use a few dabs of super rtv silicone to do it too. most bearing joints and good industrial suppliers will have it by the metre/yard
Last edit: 1 year 7 months ago by trainzkid88.
1 year 7 months ago #247603 by bcwayne
Perhaps this square o ring material from McMaster Carr would work.
www.mcmaster.com/products/rubber-seals/s...=square+rubber+seals
1 year 7 months ago #247604 by trainzkid88
yes that would be ideal. and being 3/8 size you might be able to just press it into the groove and it stay there once smeared with a little oring lube or grease
