d4 7u17432 transmission issues
1 year 7 months ago #247562 by willwingo
Going clear back to the start - how did that nut end up in the bottom of the clutch case? If that is the lower shaft, there should be a cap held on by two cap screws.
Attached is a poor scan from form FEO30521-02 showing the cap.
1 year 7 months ago #247563 by dflect1
Thanks for all replies.
How about the main gasket seal for rear trans cover. I can't make out the parts # in the library.
or could I use an appropriate size piece of some sort of mastic.
Another hang up I seem to have is I have taken the ring gear cover to gain access.
I can find the exploded view of this assembly in parts manual.
I must be stupid!
Thanks agin derek
1 year 7 months ago #247564 by dflect1
willwingo:
I found the nut and a tapered washer in the rear drain bung under the ring gear on the back of the shaft.
Which is strange if you look at drawing it shows tapered washer on the other side of the bearing.
I'm am thinking that the a hole didn't use the proper retaining clip which caused this whole issue assembled the whole transmission then noticed.
he didn't install it and instead put on the other side of bearing.
Does that make any sense or am i reaching?
Thanks fellas Derek
1 year 7 months ago #247565 by dflect1
everything in the clutch compartment came apart as described per plans.
1 year 7 months ago #247568 by willwingo
You didn't find that cover?
May have been re-assembled wrong and did not let them put the cover on. I may have an extra cover in the parts pile.
The gasket and rope type seal around the cover has been beat to death in another thread on this board. They may still be available from Cat - quite pricey. There are other alternatives.
The following user(s) said Thank You: dflect1
1 year 7 months ago #247573 by dflect1
willwingo: sorry for not investigating rope and gasket thread. I have diff cover, i took it of for access to get the shaft off and reinstall. Diff is still in place. I don't want any oil intrusion in clutch/brake case, correct?
I will get on the horn this afternoon with Cat and see were to go from here.
Thanks again Derek
1 year 7 months ago #247574 by gemdozer
I check today and have no more bottom transmiiion shaft for D4
1 year 7 months ago #247575 by dflect1
Thanks for digging in your bone pile it is probably huge!
Thanks derek
1 year 7 months ago #247577 by rax200
Hi dflect1,
I scanned in a better copy of the 7U parts manual just search 10506 in the field, here is a screen shot of the gearbox and the seal numbers which are available from cat.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
The following user(s) said Thank You: gauntjoh, dflect1
1 year 7 months ago #247584 by dflect1
Rax thank you for the images and everyone's advice. My goal is to get this done before the 4th of July. Maybe see a few of you at margarita just a couple miles from my home. Looking forward to it.
Thanks again Derek
Time to create page: 0.327 seconds
