Barndominium with shop space for my equipment, need ideas for floor fixtures.
1 year 8 months ago #246474 by PhilC
You still need an active and neutral so having them in one cable makes sense. It also explains the measured OD of the cable.
Each phase in a multiple phase system uses one of the other phases as a neutral. If you only have one phase you need a dedicated neutral.
TK88 your parents rural property is still low voltage (under 1000v). Also you can't apply Australian standards to a US installation.
1 year 8 months ago #246475 by ETD66SS
But for 3PH, it would be a 3 conductor cable from the pole to the pad transformer?
1 year 8 months ago - 1 year 8 months ago #246497 by trainzkid88
nearly all power distribution is 3 phase no matter the voltage as 3 is naturally balanced the generators are three phase or multiples of 3. so it doesnt need a nuetral, each phase is120 deg apart.
but to get single phase you need a neutral wire that why in urban areas you will see 2 levels of power cabling on the poles the ones near the top are the high voltage 3 phase area distribution cables which then feed to the transformers which supply the lower level of 4 wires which you have 3 phases and a neutral. the neutral is referenced to earth and is the normal return path to the distribution step down transformer.
the reason they are running the high voltage to your own secondry transformer is to minimise power drop becuase of the distance and you will have a better quality feed. its ohms law every doubling of voltage halves the current for the same amount of power(wattage) it also keeps the cable size down as higher voltages run at less amps and thus less heat(heat increases resistance and thus power drop) for a given wattage. id say there was also a bit of future proofing as well if you ever decided to subdivide the land they wouldnt have to run new cables.
and yess they could use a 3 conductor cable to feed your sub transformer. depends how they choose to do it. if your system had it nuetral connection on your subtransformer and not the pole they could simply run a extra 2 cables, change the transformer and upgrade the switchboard. you should get some sort of "exchange" on the sub transformer as its still working and would have plenty of life left in it and they would install it elsewhere.
Last edit: 1 year 8 months ago by trainzkid88.
1 year 7 months ago - 1 year 7 months ago #247112 by ETD66SS
So the power company wants $50,000 to install 3 phase power, so that is not a financially viable option.
Any recommendations? Is a generator a better option than a rotary phase converter? Natural gas or diesel for the generator?
Last edit: 1 year 7 months ago by ETD66SS.
1 year 7 months ago #247113 by rax200
Old vintage Cat generator is course, my preference is diesel.
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
1 year 7 months ago #247114 by ETD66SS
I don't know much about CAT GenSets. If I wanted 480 3 PH 100A at say 20kW, how big of a unit am I looking at?
1 year 7 months ago #247115 by D4Jim
Try to get in touch with ag-mike.   He has worked quite extensively on old Cat Gen systems. I haven't seen him on the board for a while so might try a PM.
ACMOC Member 27 years
D47U 1950 #10164
Cat 112 1949 #3U1457
Cat 40 Scraper #1W-5494
1 year 7 months ago #247118 by ETD66SS
Those produce a heck of a lot of power.
1 year 7 months ago #247124 by trainzkid88
while rotary converters work they are limited in what they can do and dont give good clean power the stepper motors in CNC equipment dont like it(the cousin had one and found it gave issues with his cnc machines). a genset however works better as it is a more correct waveform.
remember you need a genset 3 times the running power to start electric motors. for example a 3kw motor needs 9kw of power to start it. that's a rough rule.
there are generator calculators online to help you calculate the correct sized unit for your needs. work out what you want to run all at once and go from there. it pays to talk to someone experienced in supplying and setting up gensets so you dont over buy but also have a suitable unit with some headroom for expansion. no genset likes running at full power for long periods it shortens their lifespan. one thing to consider is you are probably only going to be using on machine at a time so pick the most power hungry one and add 10 percent to the final capacity required to get some headroom.
and there is a difference between standby and continuous(also known as prime power) rated units. some are only designed for standby use(temporary back up) and these units tend to use more fuel also there not designed to run for long periods. some units have a rating for both the continuous rating is always lower.
as for what engine to drive it diesel is the only choice. and buy a silenced unit. remember proper gensets are rated in KVA not kilowatts.
Time to create page: 0.182 seconds
