- Thank you received: 788
What about the monthly service delivery chare and rate of 3PH vs. Single?they might be able to do it by simply adding the extra meters in a bigger meter box and keep most of the single phase breakers etc as you'll still need that stuff anyway for the single phase circuits. there is no reason to replace that gear.
when the ran the 3 phase to the shed they pulled our existing cable out dragging a trace wire as the did it taped the extra cables onto the the existing one and dragged it back into place.
sadly it probably would have only cost you 1500 to 2000 bucks more at the time maybe less
For my three phase it is based on the total power consumption. So if you use 1000kw per phase it adds up to the same as if you use 3000kw on single phase. The power bill has each phase listed separately but they are then totaled and the price is the same. Price only changes if you take advantage of peak, off peak and shoulder rates. Probably different in the US though.
Yes, hopefully I hear back form them soon. Their website has none of this info...it pays to ask these questions of the utility company. they might even have a faq on their website. they would get asked this stuf frequently
trainzkid88 post=246471 userid=11838
I think here in the US, the 3 legs on the "normal street" power poles are ~14,000V each. When you build more than 250ft from the road (I'm 650ft), they transform that voltage to 7200V with a primary transformer on the pole and use HV lines underground (or above ground but that is old school) to a pad mounted secondary transformer. To keep the underground cables cheaper, they run high voltage through them, then transform the power to what your house will need, typically 240/120V ~200A at the secondary transformer.shouldnt be they rarely run that sort of voltage onto a customers premises unless its a shopping centre or something like that and in that case there wouldnt be a pole mounted transformer. your feed wont be 7.5 kv it comes off that transformer it will be 240v.
we had a power feed run off a 11kv swer line at my parents rural property the cable run was 200m of a pair of 80mm2 cables trenched in, meterbox on property pole, subboard on the shed, breakers labour etc and it was under 10 grand. mind you that was a few yrs ago so prices have increased.
ask questions and get a written itemised quote!
support@acmoc.org
- Chris R
- Jason N
