- Thank you received: 121
You really want to get those cracks sealed up as soon as you can. What they do is allow moisture into the steel core of the wheel which starts to rust and that swells up in side the wheels outer coating (Bakelite?) causing it to break off.
I'm not worries about the cracks really - they are just the product of age and (I don't think) will effect its function, but yes, epoxy would probably be a good filler.
Yes something like that should work, good plan. I just hope that I can get down to solid material!Try a roll of plumber's sandpaper a strip 16" and work all the way around buffing like a pair of shoes.
Fair point. I'll think about that. The machine has been in a pretty dry area and although not under cover, the glass in the front and the dry climate at Wilcannia have probably protected it from the effects of water. Won't be the same down here on the coast.
Oh nice! That's great. I had hoped it would just be a thin layer. I'll start there and see how it goes. Thank you for the input.It is a very thin coating on it. Have run into this before with things that sit for extended periods. I would wear gloves the first time out with it and then it should be fine. Otherwise just use glass cleaner and polish with a coarse towel. It will not take much to remove the layer of oxidation on the wheel. Sandpaper will be too aggressive for this.
Hi Deas. Thankfully I'm up in the Southern Highlands, rather than "on the coast" proper, so I don't have to deal with the salt and humidity at least - but it is definitely a lot wetter (well normally - the mechanic working on the grader for me can't even get to the machine it's so wet out there currently!)Hi, LangdonStevenson.
Yer right about the difference in climate between Wilcannia and the coast - for Americans, the equivalent would be moving it from Arizona or inland Southern California to Florida or Southern Louisiana.
The additional atmospheric moisture/humidity plus the salt air will likely get into those cracks and set the steel inside to rusting - which will then 'pop' your Bakelite coating off in chunks. Try Epoxy or Araldite or JBWeld or similar for repairing the cracks.
The 'black stuff' that gets all over your hands is simply weathered Bakelite and will wear off with use. Alternatively, you might find that a toothpaste with a gritty feel to it would remove it - MANY toothpastes have some form of fine grit in them to help remove plaque and other 'gunk' from teeth and gums. Check your own toothpaste for a starters.
I'd repair the cracks first though 'coz it might not be a LOTTA fun getting the toothpaste out of the cracks to make way for that repair.
support@acmoc.org
- Chris R
- Jason N
