Steering wheel renovation Caterpillar 212 grader
2 years 1 week ago #242665 by LangdonStevenson
One of the problems that I noted with my grader when I inspected it was that the steering wheel, which appears original, is horrible to touch - it literally sheds black crap all over your hands.  I assume that it is bakelite plastic, or something similar and it is simply decaying away with age.
I'm disinclined to just smash off the existing coating and replace it.  Covering it seems a sensible approach.  Does anyone have any experience with this or suggestions on how to deal with it?  I'd rather keep the machine as original as I can, but I can't have the wheel making my hands and clothing filthy black all the time.
212 grader, 301.5CR excavator, 226B3 skid steer (and fingers crossed a D6 8U coming my way soon!)
2 years 1 week ago #242670 by Kurt Bangert
Maybe try sanding what you have til smooth, fill the cracks with epoxy and paint the rim black. That would give you an original look and feel.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 1 week ago #242671 by LangdonStevenson
Sanding until it stops shedding sounds worth a try, thank you for the suggestion.  I'm guessing that it's only the surface that's deteriorating due to 60+ years sitting out in the sun!
That poses the question though - if I sand it back to solid material, might that be enough?  I will have to give it a go and see what happens.
I'm not worries about the cracks really - they are just the product of age and (I don't think) will effect its function, but yes, epoxy would probably be a good filler.
2 years 1 week ago - 2 years 1 week ago #242674 by steeltracs
Paint with good primer then sand then use body filler for cracks sand prime then paint multiply coats even clear epoxy paint works!
Last edit: 2 years 1 week ago by steeltracs.
2 years 1 week ago #242675 by LangdonStevenson
If I was going for a "looks like new" finish then yes something like this would be the go.  But at least for now I'd rather keep it all looking original if I can. A glossy new looking steering wheel just wouldn't feel right I think.
2 years 1 week ago #242677 by steeltracs
Then spray with clear satin finish
2 years 1 week ago #242678 by LangdonStevenson
I will start with some sanding, see what that reveals. Then yes a satin clear coat might be good.  I'd be interested to know what the original material's finish looked like.
2 years 1 week ago #242683 by restore49
Try a roll of plumber's sandpaper a strip 16" and work all the way around buffing like a pair of shoes.
2 years 1 week ago - 2 years 1 week ago #242685 by trainzkid88
you mean emery cloth tape.  available in several grades. wrap around once dont overlap and you can "walk" it around just by changing the angle of pull on the tape.
Last edit: 2 years 1 week ago by trainzkid88.
2 years 1 week ago #242687 by bernie
Powder coat?
