Steering wheel renovation Caterpillar 212 grader
Thank you received: 45
2 years 1 month ago #242665
by LangdonStevenson
One of the problems that I noted with my grader when I inspected it was that the steering wheel, which appears original, is horrible to touch - it literally sheds black crap all over your hands. I assume that it is bakelite plastic, or something similar and it is simply decaying away with age.
I'm disinclined to just smash off the existing coating and replace it. Covering it seems a sensible approach. Does anyone have any experience with this or suggestions on how to deal with it? I'd rather keep the machine as original as I can, but I can't have the wheel making my hands and clothing filthy black all the time.
212 grader, 301.5CR excavator, 226B3 skid steer (and fingers crossed a D6 8U coming my way soon!)
Fat Dan
Thank you received: 506
2 years 1 month ago #242670
by Kurt Bangert
Maybe try sanding what you have til smooth, fill the cracks with epoxy and paint the rim black. That would give you an original look and feel.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
Fat Dan
2 years 1 month ago #242671
by LangdonStevenson
Sanding until it stops shedding sounds worth a try, thank you for the suggestion. I'm guessing that it's only the surface that's deteriorating due to 60+ years sitting out in the sun!
That poses the question though - if I sand it back to solid material, might that be enough? I will have to give it a go and see what happens.
I'm not worries about the cracks really - they are just the product of age and (I don't think) will effect its function, but yes, epoxy would probably be a good filler.
Fat Dan
Thank you received: 41
2 years 1 month ago - 2 years 1 month ago #242674
by steeltracs
Paint with good primer then sand then use body filler for cracks sand prime then paint multiply coats even clear epoxy paint works!
Fat Dan
2 years 1 month ago #242675
by LangdonStevenson
If I was going for a "looks like new" finish then yes something like this would be the go. But at least for now I'd rather keep it all looking original if I can. A glossy new looking steering wheel just wouldn't feel right I think.
Fat Dan
2 years 1 month ago #242678
by LangdonStevenson
Then spray with clear satin finish
I will start with some sanding, see what that reveals. Then yes a satin clear coat might be good. I'd be interested to know what the original material's finish looked like.
Fat Dan
Thank you received: 51
2 years 1 month ago #242683
by restore49
Try a roll of plumber's sandpaper a strip 16" and work all the way around buffing like a pair of shoes.
Fat Dan
Thank you received: 809
2 years 1 month ago - 2 years 1 month ago #242685
you mean emery cloth tape. available in several grades. wrap around once dont overlap and you can "walk" it around just by changing the angle of pull on the tape.
Fat Dan
Thank you received: 94
Time to create page: 0.212 seconds
