"New" 5U D2
2 years 9 months ago - 2 years 9 months ago #235559 by restore49
Replied by restore49 on topic "New" 5U D2
Just repaired a friends D6 tank - cut out the bad made a new top (14 Gauge?) with 1/2" overlap and solder on. His halves were brazed together (1953). Can make the missing contactor in cap from carbon center of D cell Battery - I may have one. New brush #4F2302 (7H3885) Bob
Last edit: 2 years 9 months ago by restore49.
The following user(s) said Thank You: Kurt Bangert
2 years 9 months ago #235560 by neil
Replied by neil on topic "New" 5U D2
Your D2 was manufactured in 1938 and was purchased from Goughs by W. Gregory of Waiau. For the tank, I'd say just get a new one. For the mag, if it's not hot, then send it away to be restored. They come back like brand new. For the carb, you'll need the kit but also there is some technique to cleaning them out properly. When you remove the bowl from the throttle body, be careful because there's a thin brass tube that screws in from the other side and goes all the way across the throttle body into the bowl assembly. If you can gently unscrew it first, that's best but sometimes they get seized in there and it's often best to leave them alone as I don't know if you can get them new. You may need to drill out the lead plugs on the bottom of the bowl to clean the passage that runs across the bottom to the well. They're easily to replug with 177 calibre air rifle slugs and if you want, a bit of glue over top of the slug. The "bull's eye" gasket between the throttle body and bowl has a center ring that sometimes fails so make a note if that was the case when you disassemble it. Finally, there's a plug situated just under the throttle plate when it's closed that acts as the "jet" for the idle circuit. Check that the notch in that plug is under the plate (on the engine side when the plate is closed) so that the idle circuit can feed gasoline to the engine at idle. Mine had been reversed and would not idle despite a full clean and refurb. Very easy fix. You just find a close fitting punch, punch it all the way in, then fit it again from the outside the right way up. Make sure the throttle plate is out of the way if you do this.
2 years 9 months ago #235562 by bboaz
Replied by bboaz on topic "New" 5U D2
I' have had really good luck making pony tanks out of stainless steel. Not original but I have had gas set in tanks for over a year and still be just as clear as the day it was put in there.
The following user(s) said Thank You: Kurt Bangert, steve_s
2 years 9 months ago #235564 by Kurt Bangert
Replied by Kurt Bangert on topic "New" 5U D2
Nice work! Thanks to all for the advice, very appreciated.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 9 months ago #235565 by Kurt Bangert
@Neil, this is a 5U, I’m pegging it as 1948. I definitely appreciate the carb advice.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 9 months ago - 2 years 9 months ago #235570 by Markds3
Replied by Markds3 on topic "New" 5U D2
Awesome to see another 5U in great original condition, and I'm following with great interest! here's my one owner 1950 D2 (5U5373) with an original 3955hrs, there's a thread somewhere here on it:
Last edit: 2 years 9 months ago by Markds3.
2 years 9 months ago #235571 by Kurt Bangert
Wow - super nice! Mine is showing 3,858hrs, FWIW.
If the topic is interesting, I'll keep posting, if not, no harm done.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
The following user(s) said Thank You: Markds3
2 years 9 months ago - 2 years 9 months ago #235572 by Markds3
I just checked back and looked at my thread and I made a mistake, it showed 3940hrs when I got it and I've done 15hrs on it since - so very similar to yours:
www.acmoc.org/bb/discussion-d72/27964-fo...iginal-hours?start=0
2 years 9 months ago #235573 by Kurt Bangert
Your paint is incredible, much better condition. That machine was clearly well taken care of.
D4 D 78A 6678
D4 6U 1139
RD4 4G223W
D2 5U 1164
JD 350B
JD 420C
2 years 9 months ago #235575 by Markds3
Yes, the old owner was pretty fastidious (although not very good at keeping the air filter bowl clean) and always stored it in the same place, undercover, in his shed. Unfortunately, he passed away in 2013 and his son, who now runs the farm, didn't even know how to start it, let alone drive it! It was an absolute stroke of luck for me to get hold of it, as it certainly wasn't advertised, and I only learned of it through an ex-employee who used to drive it.
As for your comment above, ABSOLUTLEY, keep posting, it is very interesting, and this sort of thread is why I keep returning to this forum...
The following user(s) said Thank You: side-seat, Kurt Bangert
Time to create page: 0.199 seconds
