- Thank you received: 13
The waterpump seems to be all connected with some sort of vertical cooler, than a long barrel cooler running horizontal down where it would be fantastic fun to remove. It is really hard to figure out what is what. I have service and parts books but they don't show much of this.The transmission cooler just has engine coolant and the trans oil going through it, the engine oil cooler is separate, behind the water pump.
Here is a question I am trying to answer right now. We know the trans is contaminated. Potentially is eating itself. It seems plausible that the pump could not deliver oil due to the inlet being so plugged, but that is a gamble. However, I believe the TC also pulls oil from the trans? If the TC is toast again, I will probably need to walk away. I can do many complex repairs inhouse, but I can't build a TC.There should be trans oil in the cooling system too, after you replace the cooler flush the engine cooling system with water and a non sudsing soap, Bon-Ami. The trans/strg clutch compartments can be cleaned by just adding a "cheap" 30W drivetrain oil and operating it and then let sit overnight and drain off the coolant then run again and change oil and repeat till you have clear not milky oil.
This is a gamble, BUT, I do not see anything in the invoices that the dealer even touched the filter screens when it was in with a known bad bearing. I have the list of parts used, and I doubt the dealer would waste the time to clean them, especially in a failure. I am not sure if I will either. They also likely did not do any rinse of the trans after that. So just doing a simple oil change may not have got it cleaned up.OOOHHH!!! those strainers! not good! Like I mentioned, go through the whole back end. The steering clutches are pressed on the cross shaft, the steering clutches are bolted to flanges on the pinion gears which go into the finals, the seals are in the steering clutch housing/holders between the clutches and finals. Major work, get a service manual if you do it yourself.
support@acmoc.org
- Chris R
- Jason N
