Combustion chamber question..
16 years 3 months ago #19644 by crazyfazy_7
Replied by crazyfazy_7 on topic ...jackpot!!
for those of you who helped out on trying to find the tool for the round retaining nut for the fuel injector...I think this is it!
i296.photobucket.com/albums/mm169/fazer_1/caterpillartool.jpg
...now, I just need to find one!:)
Thanks to all who helped me out!
Greg
16 years 3 months ago #19652 by Old Magnet
The 3208 is to new for the "Service Tool" information I have:)
How about a picture of that injector installation so that we can identify for sure what this application is!!!
16 years 3 months ago #19654 by crazyfazy_7
...we're wondering if somewhere along the line, a previous owner maybe swapped out the injectors with ones from something else. Is that possible?:confused: I'll post some pictures as soon as I can to help with identification.
16 years 3 months ago #19656 by Old Magnet
Pictures will help tell:)
16 years 3 months ago #19675 by jw45
Replied by jw45 on topic injector nozzle@holder
oops messed up
16 years 3 months ago #19736 by edb
Replied by edb on topic Glow Plug Tooling
OM, the tool is indeed the sleeve metering fuel system injection pump retaining nut removal tool---2H7479.
It appears to be a revival of the socket (item #2 pictured) from this tool Grp. used to service G/plug equiped engines. The splined nut is used to gain the necessary clearance with the G/plug installed as stated earlier by others.
Hope this helps.
Eddie B
16 years 3 months ago #19756 by Old Magnet
Hi edb,
Thanks for the info.
Could we conclude that this is on a D315 engine....I'm thinking the D330 is a different retaining nut thread and a hex pattern??
16 years 3 months ago #19780 by edb
Replied by edb on topic Splined Inj. Retaining Nut.
Hi OM,
to the best of my knowledge the splined nut was used on the smaller early engines, as you state, as originally they were not designed to have G/plugs.
The later engines were obviously designed (D330, 3300 series etc.) with bigger prechambers to accept the G/plugs without the need to find the extra retainer nut clearance. I would also say that the likes of D342 etc that the precombs were large enough to accept the G/plugs without the need for the splined nut. I feel sure that I only recall seeing the splined nut and G/plugs on the smaller engines.
16 years 3 months ago #19838 by crazyfazy_7
Hey Old Magnet and gang...got the splined nut out with that special socket, no problem! I don't know how we'd have got those nuts out if we didn't have that tool! The O rings were shot and they were letting water squirt out around the pre-comb. chambers. ...So am I understanding correctly that these are factory retainers on the older D315's? Also... I have the valve pan removed and noticed that there is an awful lot of valve lash. Could you tell me how much the valve clearance should be on these old engines? Thanks again to everyone for all the help and advice you've given!:)
16 years 3 months ago #19847 by SJ
Replied by SJ on topic valve Setting
The setting should be .010" hot and if cold add an extra two (.012)
