Combustion chamber question..
16 years 3 months ago #19599 by crazyfazy_7
Hello again...still workin' on that ol' Cat from previous posts and I have yet another question. Is there a special socket that fits the fuel fitting that screws into the combustion chamber to remove it on a 955C, motor #12A 781? It seems to have a knurled edge. I've tried different sockets with no luck. I have the tool (splined bolt) to remove the combustion chamber so I can install new washers and O rings, but I can't get the fitting that the fuel line screws onto out to remove the chamber. I'll learn the ins and outs of this ol' machine yet!:confused:
Thanks in advance for your response!
Greg.
16 years 3 months ago #19600 by ccjersey
Have you tried a 6 point 1" socket? Torque to 100 foot pounds.
16 years 3 months ago #19603 by crazyfazy_7
I haven't tried a six point socket. The fitting is round with small notches all the way around it. I've tried 12 point 15/16" sockets and they almost work, but just barely slip when torque is applied. I will try the 6 point, 1" tomorrow though, Thanks for your answer.
Greg.
16 years 3 months ago #19607 by WraithGTO
Not sure but this is just a idea,could it be a Torx style head or similar
16 years 3 months ago #19609 by crazyfazy_7
...not sure if they had torx when these ol' machines were made, but it's an idea. I'm also not sure if they have a torx socket that big. The biggest I've seen is E-20, but again it's worth a try! Thanks for your help!:)
16 years 3 months ago #19611 by WraithGTO
No worries, Thought it may be a long shot
16 years 3 months ago #19612 by SJ
Replied by SJ on topic Tool
I can,t remember for sure but it seems Cat had a special socket for it that was splined for it.Been too many years since I worked on one.
16 years 3 months ago #19613 by ccjersey
Just wondering if someone did a neat job on it with a cold chisel? Doesn't sound like it though. All of them I ever saw were a plain hex nut. This would likely be a D330, D330C or a 3304???
We are talking about the hold-down nut for the injector in the PC chamber, right? If CAT made it, they will sell a tool to remove it. Might not be as much trouble as making something.
16 years 3 months ago #19614 by 8C 361
If you have the 1" holdown nut out, the fuel fitting as you are calling it comes straight out. It doesn't un-screw. It might be stuck in there, maybe if you try a little penetrating oil and wiggle it a bit it will come out.
Tom
16 years 3 months ago #19616 by Old Magnet
Tom has it right:)
No special tool required......same as D4-7U D-315.
They have been known to be a bit sticky but need to pull straight out.
