Combustion chamber question..
16 years 3 months ago #19599
by crazyfazy_7
Hello again...still workin' on that ol' Cat from previous posts and I have yet another question. Is there a special socket that fits the fuel fitting that screws into the combustion chamber to remove it on a 955C, motor #12A 781? It seems to have a knurled edge. I've tried different sockets with no luck. I have the tool (splined bolt) to remove the combustion chamber so I can install new washers and O rings, but I can't get the fitting that the fuel line screws onto out to remove the chamber. I'll learn the ins and outs of this ol' machine yet!
Thanks in advance for your response!
Greg.
Thank you received: 10
16 years 3 months ago #19600
by ccjersey
Have you tried a 6 point 1" socket? Torque to 100 foot pounds.
16 years 3 months ago #19603
by crazyfazy_7
I haven't tried a six point socket. The fitting is round with small notches all the way around it. I've tried 12 point 15/16" sockets and they almost work, but just barely slip when torque is applied. I will try the 6 point, 1" tomorrow though, Thanks for your answer.
Greg.
16 years 3 months ago #19609
by crazyfazy_7
...not sure if they had torx when these ol' machines were made, but it's an idea. I'm also not sure if they have a torx socket that big. The biggest I've seen is E-20, but again it's worth a try! Thanks for your help!
16 years 3 months ago #19612
by SJ
I can,t remember for sure but it seems Cat had a special socket for it that was splined for it.Been too many years since I worked on one.
16 years 3 months ago #19613
by ccjersey
Just wondering if someone did a neat job on it with a cold chisel? Doesn't sound like it though. All of them I ever saw were a plain hex nut. This would likely be a D330, D330C or a 3304???
We are talking about the hold-down nut for the injector in the PC chamber, right? If CAT made it, they will sell a tool to remove it. Might not be as much trouble as making something.
Thank you received: 47
16 years 3 months ago #19614
by 8C 361
If you have the 1" holdown nut out, the fuel fitting as you are calling it comes straight out. It doesn't un-screw. It might be stuck in there, maybe if you try a little penetrating oil and wiggle it a bit it will come out.
Tom
Thank you received: 820
16 years 3 months ago #19616
Tom has it right:)
No special tool required......same as D4-7U D-315.
They have been known to be a bit sticky but need to pull straight out.
