1956 D6 9U Cable Blade Restoration
Thank you received: 999
2 years 10 months ago #234532
by Rome K/G
That would be in the #24 cable control parts book. I dont have mine handy at the moment.
D6cat9U
Thank you received: 21
2 years 10 months ago #234535
by D6cat9U
I would truly appreciate it if you could help me, I would like to buy a book for myself, can you tell me where to get one.
Thanks, and happy new year.
Mike
Thank you received: 98
2 years 10 months ago #234539
by D6cat9U
Can you please send me a link or tell me the description its listed under?
ThanksĀ
Mike
Thank you received: 143
Thank you received: 276
2 years 10 months ago #234558
by rax200
If you are a payed member you will have access to the Technical Library and the parts books are in there
Regards
Daryl
1937 RD4 4G4368
1940 D4 7J3717
1942 D4 7J9915SP
1942 R4 6G2550SP
1944 D4 2T6584SP
1945 D4 2T8978SP
1946 D4 5T6271
1956 D4 7U37855
1954 DH226 S/N 89 Howard Tug
Thank you received: 348
2 years 10 months ago #234689
by D6cat9U
Thanks so much for the info on the manual, picked one up on ebay, Ill be going through the attachment with a full service and new disc assembly.
I'm trying to get a head start on the cable blade attachment, can anybody tell me how full this should be as I dont see a plug to check oil level, also what weight oil, Smells like 90 weight when I dumped it out the bottom drain plug, also can I get this brake lining done at a brake shop or do I need to order the lining from Cat. Also can I remove the inner plate through the circled bolt, I need to get in and clean the actuator that moves the discs in and out by pulling and pushing the blade lever.
I can't thank you all enough.
2 years 10 months ago #234695
by Rome K/G
Should be filled up to the plug threads. Looks like the brake band lining is soaked up with oil, it should be replaced. The oil seal need to be replaced also on the drive shaft.
D6cat9U
Thank you received: 663
2 years 10 months ago #234696
You can get the brake lining done at a brake shop. They'll glue it on
D6cat9U
Time to create page: 0.422 seconds
