Cat twenty two timing.
5 years 11 months ago #193777
by 55BelairDan
I was out working in the garage today. I set the impulse on the mag to 30 degrees. So now the impulse trips right at tdc and the mag mark lines up with the rotor in mag. It was set at 20 degrees before. I have the wires all in the correct order. I took the plugs out and watched them spark in the correct order when I was cranking. The points open up right as the mag mark lines up on front pulley. I have tried a little gas in spark plug holes and a little ether in intake haven't gotten more than some backfires out the exhaust. Sorry for the rambling but I'm not sure what to do from here. If anyone has any suggestions it would be apreciated
Thank you received: 344
5 years 11 months ago #193780
by edb
Hi Dan,
now assuming that your ignition is timed and sequenced correctly, when cranking with the spark plugs in, does each cylinder seem to have compression/resistance ?
A possibility is if one or more cylinders have little or no compression you may have crud stuck on a valve seat holding one or both of that cylinder's valves open. If this cylinder tries to fire with a leaking valve/s then it can bang in either manifold--depending weather it is an Inlet or Exhaust valve that is leaking.
If you previously checked your valve lash and found some loose--maybe due to crud under the valve--and you adjusted the valve lash, now the crud may have been dislodged and so you could have no valve lash on the loose ones, so now the valve/s do not get to seat and so leak by, as evidenced by the banging in the manifolds.
A rather rough way of maybe getting a leaky valve, held open by crud, to seat is to lightly tap the end of the rocker arm over the valve end on a valve that has lash clearance and with the piston down from TDC but on the compression stroke-- with a soft face hammer a few times so as to bounce the valve on and off its seat and see if the crud can be dislodged and the valve to seat better to allow a start. Once the engine is running the leaks usually settle down--if not a valve grind may be in your future.
Hope this helps.
5 years 11 months ago #193781
by 55BelairDan
Thanks. There seems to be pretty even resistance but not a ton of it. I'll give the tapping method a try and see if anything changes.
Thank you received: 656
5 years 11 months ago #193782
Twenty-Two doesn't have a whole lot of compression resistance if my cousin's is anything to go by, but it starts first pop every time. What's the spark look like - fat and blue or weak and yellow? Former is preferable. See if you can flood the engine as well. If you can, then you know you're getting enough gas (shut off fuel, open choke, wide open throttle, and crank it half a dozen times and it might start). If not, that might be part of your problem as well.
If you get tired of cranking, you can also get the 3pt on another tractor and hook it directly to the drawbar, put the crawler in Reverse and head off around the paddock.
5 years 11 months ago #193790
by 55BelairDan
Well I went back out in the garage and tried some things. And I came up with my plug wires were screwed up I watched for what cylinder was on compression stroke and then what plug sparked and matched them all up and now I got it to fire up! Now I have to work on my carb tuning! Gauge said 50lbs oil psi so that seems good!
Thank you to everyone who helped me!
Thank you received: 98
5 years 11 months ago #193799
by edb
Hi Dan,
thanks for relaying your good news.
Remember, we all started with very little knowledge of these things magneto.
I was lucky to be taught by my Dad and later on by Cat Tradesmen.
I got to overhaul magnetos at The Dealer way back when.
Sometimes the learning curve can be steep BUT perseverance and thinking outside the box can do wonders.
