Reviving another old relic - D9G
5 years 9 months ago #196782 by Misterskill
Hi, Misterskill.
Man, yer gotta LOVE innovation.
Nah. You don't want a D2. Ev'rybody - and their dog - has a D2. How many people do you see on here with a D9G dozer with a multi-shank ripper?????????
Good point. Although I admit I felt a pang of jealousy when i watched a bloke on youtube pull his D2 trans out in his garage with an block and tackle. my poor old land cruiser will be sweating when i put mine on it and limp it home haha
Thankfully at 29 I'm still able to grovel around in the dirt and lift heavy stuff
5 years 9 months ago #196784 by d9gdon
Good to see that you're still making progress on it.
That bushing looks really bad.
5 years 9 months ago #196789 by Rome K/G
Have a look at this for the latest in welding comfort! there are probably 4 or 5 strategically stashed around the yard.
Fun? is that what it's called. I caught myself the other day, whilst once again starting the excavator to lift something, (or belting something with the 12lbs sledge) muttering "I should have bought a d2..." :rofl:
Alas we soldier on! Go hard or go home :rofl:
2 more rams and hoses getting done on the KATO tomorrow so that's another job out of the way. Then my off-sider is away on holiday again in march so I'm off to try and make a bit of extra cash and keep the whole project going
Keeps the rear end cool and good ventilation when gas pressure builds up! lol
5 years 8 months ago #198320 by Billy-
Well, back into it. Main ram seals done on the excavator so back into the old rig
Track split and cylinder out. Clean it up tomorrow, then send the seals off to get replacements.
Also found a picture of it working back in the old days. 1967, she would have been a flash rig back then!
Thats a neat picture of her back in the day. Was she a opal miner from new?
Cheers
Billy
5 years 6 months ago #201586 by Misterskill
Cheers
Billy
Wouldn't have been new, be bloody close though. Imagine floating that thing up 600km of dirt road back in 1967....
Alright so we are back into it.
Too cold to do any of the blade welding job so we've parked that until it warms back up again. Hydraulic shaft and coupling are back along with bearing and seals, only thing i stuffed up was i didn't send the disc pre-load washer with it. Reckon i can get one anywhere? got a few part numbers from different suppliers for something close but no stock in Australia, best is a 3 week wait out of Germany. managed to get a few wave washers and we are going to try and see if that works.
Anyway, here is a shot Trunnion ball. No idea how a chunk of steel ends up looking like this, but apparently it can
And the shiny new one. that's both done now
Had a few rust holes up on top of the blade where dirt seems to pile up
so we ground the worst of it out and built a half inch plate box thing over it
Yeah, we ran out of paint this afternoon haha
If these washers turn up (express posted from Sydney on Friday so can't be far away) we should be able to get the hydraulics back together over the weekend and the blade back on. Stand the tractor up and do all the rubbers then slide that track with the crook bush out. We are getting close to pulling the trans out which i hope is the last big job.
Anyway this is the opal we are chasing, found this a few weeks ago. going through some old tailings with one of my other machines.
5 years 5 months ago #202293 by Misterskill
Another weekend, more boxes ticked
Got some hydraulics down, seals are shot and rams need re-chroming.
Both cylinder nuts were loose so going to take the good one down and check that too and throw a seal kit in it while we are at it. Need to chase up some replacement balls as they are pretty crook too.
Started on the trans. only broke one spanner so that's pretty good. (sacrificial ring spanner we cut the end off and put a 1.5m cheater pipe on to get the uni bolts undone haha) All pipes disconnected and scavenge pump removed. Got to make up a lifting jig to get the torque divider out and i stuffed up and only ordered 2 lifting lugs for the trans instead of 4 (DOH!) so there will be another week or so wait on that.
Parts for the radiator fan idler should be here this week so we can start on that while we are waiting.
5 years 5 months ago #202294 by Deas Plant.
Replied by Deas Plant. on topic Great Stuff.
Hi, Misterskill.
Great stuff. It's good that hear that you are making progress. I have runna LOTTTTA of different machines over my time in the saddle and I still think the D9Gs were some of the best. In fact, I preferred them to the D9Hs.
5 years 5 months ago #202458 by Misterskill
And out she comes
5 years 5 months ago #202486 by edb
Replied by edb on topic Torque Converter Scavenge Pump
Hi Misterskill,
sadly, it looks like you missed removing the T/C Scav. Pump before removing the entire T/C assembly from the engine.
It is not unknown for the T/C to drop down onto the scav. pump drive gear and bend the scav. pump input shaft.
The T/C scav. pump should be removed before the T/C assembly is removed from the engine and re-fitted after the assembly is back in place on the engine.
Sorry for the heads up now, I hope it is fine. If the shaft is bent and not noticed then a rotating bending fatigue failure of the shaft usually results in carnage in the T/C housing when the scav. pump gear gets loose.
5 years 5 months ago #202493 by Misterskill
Hi Misterskill,
Very good point. Will check.
Time to create page: 0.438 seconds
